Lights, smoke, sound, help Options
#1 Posted : 10 April 2015 13:26:50
Hi all looking for some views and opinions please. BigGrin
I will be getting stuck into this build in 2 or three months time...
http://forum.model-space...spx?g=posts&t=15092
, due to its size it would be a crime not to add Lights, smoke and sound. The manufacturer recommend some bits n bobs but I was interested in forum members views on best kit and brands for smoke units, sound units and the best way of tackling the lighting – not done any of this before so any views appreciated.
I will be RCing this to so any vews on that also welcome.
#2 Posted : 10 April 2015 13:43:45
Initially you need to determine what power you intend to use, be it 6v or 12v
Smoke generators
http://www.cornwallmodel.../model_electronics.html
Sound and lighting systems
http://www.cornwallmodel...log/sound_lighting.html
You'll also find this useful
http://www.westbourne-mo...ms_for_model_boats.html
budgie
#3 Posted : 10 April 2015 14:42:39
BigGrin Hi Jase
try the below links for ideas in what mat be required
http://www.action-electronics.co.uk/
Click Diagrams n Articles
http://www.action-electr...%20C%20J%20Williams.pdf
If u contact them direct with the model you are building they may do a diagram for you to suit your specific needs
#4 Posted : 10 April 2015 20:56:14
thanks both for the links, very useful
J
Garth
#5 Posted : 12 April 2015 20:36:17
Hi Jase,
Perhaps you can consider LED strips for ambient interior lighting. Each one is about 50mm x 10mm & has 3 LED's. They require a 12volt DC supply. They can be daisy chained together and are easy to install. In South Africa they are available from electronic dealers & specialist lighting retailers. There is also a waterproof version that may work in a RC model.
Hope this helps,
Kind regards,
Garth
"Measure twice, cut once!!!"
Finished!!! HMS Victory,
Current build: Black Pearl.
Wish list: USS Constitution.
#6 Posted : 12 April 2015 22:18:42
Thanks Garth once i have a shopping list i will post up and see what people think
J
This page was generated in 0.045 seconds.
