5 Pages 123>»
Malc's M23 - James Hunt Options
RM1
#1 Posted : 12 April 2015 13:39:44
Well it had to be another Mclaren didn't it?
Not a magnificent 1/8 ( unfortunately ) but a 1/20 Tamiya kit.BigGrin
I've got the sponser decals and a Tamiya upgrade P/E set.
It will give me something to do while awaiting the delivery of the Senna 4/4.
Three months and still not got the first pack yet.
Never mind.. this will keep me busy.BigGrin
Malc.
mark8454
#2 Posted : 12 April 2015 14:33:01
I will be watching with keen interest and will look for inspiration! :)
#3 Posted : 12 April 2015 17:12:53
Nice kit Malc, I have exactly the same one with the same extras and which I did start building on here previously when I was 'SennaMentalMe'? I was only thinking quite recently that I should perhaps reinstate the M23 diary and carry on from where I left off, but I think that I really ought to concentrate on my 1:32 Spitfire Mk.IX build and three others that I already have on here first?! Blink Sad
#4 Posted : 12 April 2015 17:48:28
Nice looking kit and although it isnt a 1/8 I'm sure you will do it justice Cool
#5 Posted : 12 April 2015 20:17:13
BigGrin Nice kit, will look forward to your buildCool Cool
RM1
#6 Posted : 18 April 2015 16:55:32
Here we go. First off the DFV.
I'm going to use Alclad 2 a little more on this build ( I need to practice Airbrush cleaning !! ) so I've used Tamiya grey surface primer then Alclad black and finished with Alclad Aluminium. The covers are in Tamiya Matt black.
Malc.
RM1
#7 Posted : 18 April 2015 16:58:31
A little bit of detailing to finish.BigGrin
#8 Posted : 18 April 2015 21:47:38
BigGrin Nice start and nicely done MalcCool
#9 Posted : 21 April 2015 18:36:35
Nice start to the build Malc and that Cosworth DFV looks pretty realistic already - well done!! Cool ThumpUp
Looking forward to seeing this build develop further and who knows, it might even inspire me to carry on with mine sooner rather than later?
RM1
#10 Posted : 26 April 2015 11:14:11
I decided to use a slightly thinner wire for the plug leads and added a red sleeve to each at the distributor made from thin electrical cable with the wire striped out.
RM1
#11 Posted : 26 April 2015 11:17:22
Not happy with the venturis that came with the kit. The plate that joins them and the chrome finish are not to my liking.
So I nibbled the plate away with a side cutter and smoothed the edges out. Finished with a light spray of Tamiya chrome silver. Plus a small dab of flat black in the holes.
RM1
#12 Posted : 26 April 2015 11:21:52
Early stages with gearbox assembly.
#13 Posted : 26 April 2015 15:44:15
Nice work Malc and making good progress with the engine/gearbox assembly. I did exactly the same as you with the induction trumpets on my kit and they certainly look much better and more to the point, accurate with those plates removed - well done. Cool ThumpUp
RM1
#14 Posted : 01 May 2015 16:30:37
The rear discs and brake ducts are quite straight forward. There's a couple of PE parts to add to the sidesBigGrin and I've added some ventilation with a small brush and much cursing!Laugh .
RM1
#15 Posted : 01 May 2015 16:35:18
There is no piping for the fuel lines in this kit so I've added some with thin electronic wire sleeving. Also added a fitting to the Fuel pressure relief valve ( I think that's what it is ).
RM1
#16 Posted : 01 May 2015 16:36:30
The parts so far.BigGrin
RM1
#17 Posted : 01 May 2015 16:41:41
The rear spring units are one piece mouldings so I sprayed them gloss balck then masked off the core and sprayed the spring coil tamiya metallic silver.
#18 Posted : 01 May 2015 20:11:34
BigGrin Very nice work MalcCool
#19 Posted : 01 May 2015 22:21:06
Great work, that engine looks awesome, the detail is fantasitc, look forward to more
dandare
#20 Posted : 14 May 2015 13:08:25
i agree
that engine looks fantastic
great job Malc
Dan
5 Pages 123>»
This page was generated in 0.194 seconds.
