Hi Andy. Looking realy nice, agree with alans comment about the contrast. of the wood. look forward to the next instalment Ian Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
 Thanks for looking in and your comments Ian Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Looks fantastic Andy, I missed your last update somehow  Very natural looking build. Steve
 Hi Steve Thanks for looking in and your comments, personally I have always thought the bare wood build would suit this build down to the ground to show off all those hardwoods and different colours. Although in the same way your painted build now gives others the chance to view both versions and decide what type of finish suits them. Regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Hi All Its been a while but here is an update, I have carried on with the adding of decks and hull planks and now have reached the main deck area still some tidying to do and hull planking to add but coming along nicely. More soon. Regards Andy arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Rank: Vice-Master        Groups: Registered
Joined: 17/11/2012 Posts: 863 Points: 2,608 Location: Gohfeld (Germany)
Hi! A fantastic work you made, very well done! Regards, Bernd
Some more lovey work there Andy
 Thanks for looking in and your comments both of you Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Very nice Andy, do love the colour you have chosen for those decks, certainly gives it that aged and well used look.... Regards Alan
 Hi Alan Thanks for looking in and your comments and thanks for the comments on the decks, I have been using Rustins dark teak wood dye on them then a couple of coats of matt varnish to seal them. Regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 A little more done, top deck is on and one gunwale has been fitted. more soon. Regards Andy arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Hi Andy. Realy looking superp. Love the contrat between the decks and the outside planking colours. How many cannons are included. Look forward to seeing more Ian. Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
Brilliant work Andy, very neat and love the realistic dark stain of the the inside Steve
 Thank you both for looking in and your comments @ Ian there are 16 cannons all together 8 each side, They look slightly bigger than the ones provided for the full kit but have the cast metal carriages aswell. Regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Hi All The other gunwale has been added and the chainwale and belaying pin strips added along with some strip on the upper deck this finishes the majority of the hull build. The hull was sanded back and several coats of matt varnish sprayed on. Next it was a start on the lower mast which has been tapered and the rubbing paunches and cheeks added. The thin strip provided for the rubbing paunches/cheeks is a little stiff so I recommend soaking in water before fitting in place. Just a note on the pictures the ones before the mast picyures are of the hull after sanding but with the metal gun ports added to show how she will look and the ones aftre the masts are of the hull after 3 coats of matt varnish. More soon. Regards Andy arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Hi Andy! Very nice, it´s looking great! I love the colours, is it the original delivered wood ? Regards, Bernd
 Hi Bernd Thanks for looking in and your comments, all the wood on the outer hull is as supplied with the kit and just matt varnished, just the inner hull has been uniformly coated with Rustins dark teak wood stain to get that dirty used look I wanted. Regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Stunning work Andy, looks absolutely fab.... Regards Alan
 Hi Alan thanks for looking in and your comments Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Hi Andy. Looking superp. Look forward to seeing more Ian. Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
