hull planking Options
johny5
#1 Posted : 08 September 2010 13:11:30
any one no wher i can get some spare woodstrips for the hull if broken most of mine
#2 Posted : 10 September 2010 08:42:22
you could contact Deagostini customer support for some more or go to Cornwall models on line.
how have you broken them? I might be able to help you not brake the next lot!
johny5
#3 Posted : 10 September 2010 08:54:35
tring to bend them its my fist wooding ship
#4 Posted : 10 September 2010 09:43:36
hi jon5,I think we are going to get a lot of this from the less experianced modelers,go to www.cornwallmodelboats.co.uk and order 5x2mm. lime wood strips.much much quicker then de-ag.less hassel,and also buy an electric plank bender,30 quid,I know expensive,but a tool that will pay for itself over and over,by saving having to buy more wood.then soak about a third of it overnight,I use a mop bucket,and dunk them there upto a third of their length,then I use the electric bender,mark all the formers on the plank first,2mm. thick planks are difficult to bend at the best of times,so take it slowly,start by doing it with a slight bend,then slowly increasing the bend until you have the right set.
johny5
#5 Posted : 10 September 2010 09:51:08
hi just went to ther web site but thay dont do the right size 5x2
Jack Sparrow
#6 Posted : 10 September 2010 09:52:46
Totally agree with Karl, Cornwall models are great. I get all my paints and wood and fittings from them. My Black Pearl upgrades are all from there. And the electric plank bender is a must. I tried the nipper one and I couldn't get on with it. The electric one is so easy to use with the former, I soak my planks first for a couple of hours in warm water, and then as Karl says, build up the bend till you get it where you want it, re-soaking if needed. It was worth every penny!!!!
johny5
#7 Posted : 10 September 2010 09:56:26
just went to ther site but cant get the righ size 5x2
piot007
#8 Posted : 10 September 2010 10:02:31
Try to dip them in warm water to loosen the fibers. GENTLY bend them, dip again and bend GENTLY again.
Alternatively you could invest in a proper plank bending tool, found on 'Cornwall model boats' site. (just google it).
If your a subscriber then you should have received a free plank bender from the free tool kit. This tool crimps/creases the plank on the side that's facing inwards. I think you still need to damp it down again to help with loosening the fibres of the wood.
You really should do some background reading into planking and techniques. There is lots of info to help, but you must research what your doing BEFORE you do it.
Ive mentioned to you before that help is only a click away.
Dont hesitate to ask.BigGrin
Im new to this as well. but if i can help i will.
johny5
#9 Posted : 10 September 2010 10:09:09
just went to conwall models web site but thay havent got the right size planks for the hull 5x2
piot007
#10 Posted : 10 September 2010 10:23:36
i think if you looked harder then you'll find these in the size you want
MAPLE
WALNUT
BEECH
LIME
MAHOGANY
All of these are in 2x5 mm strips.
Go to building materials, timber.
Pick which wood you want then scroll down to about half way down page.
The sizes go from the thinest, (at the top of the page), runs through that thickness variant but differs in width (going down the page, they get WIDER) then the next thickness variant starts.
Im messing this up.LOL
this will explain better
0.5x1
0.5x2
0.5x3
1x1
1x2
1x3
2x1
2x2
2x3Cursing somebody will do a better job of explaining than me!!LOL LOL
piot007
#11 Posted : 10 September 2010 10:26:15
I think you should be looking for 2x5 not 5x2, otherwise it will be one huge hull and look all wrong, thickness x width is how it goes i think
Dontshootme
#12 Posted : 10 September 2010 10:51:31
Posted link to right page in your other thread but here it is again
http://www.cornwallmodel...1LI2_2e0050#a1LI2_2e0050
Wilberforce
#13 Posted : 10 September 2010 12:47:43
@Karl113
Reading your post re the soaking of the planks, when I was reading the posts about the planking, I am nowhere near planking yet, I was wondering about soaking so thank you for that advice. Do you soak, bend, leave to dry then attach or soak, bend, attach and then let dry?
This is my 1st build and so want to do it carefully, this model is going to cost me about ZAR8000 when done so I dont really want to go and have to buy too many planks because I cocked the thing up in the 1st place.
Current build : The Victory
Pending builds : none - yet
Built loads of bikes trucks planes and boats - all plastic kits.
on wish list - a 1:24 spitfire, in wood, plastic, just as long as I can build it :)
psyshowbob
#14 Posted : 19 September 2010 00:10:06
i find that boilling the kettle then putting them in for a cupple of minnits is fine. i sand a light chamfer then mark.cut to size. glue ribs . i pree drill then use a small hamer to hone the nales .when dry snip nail heads tap in with hamer then sand .. geting good results so far.. regards bob .hic beer kicked in :)
piot007
#15 Posted : 19 September 2010 21:35:10
Hi all.
This is how i will lay my planks. I need to ask advice from you guys if its the right way.
First dry place plank, mark and cut to length.
Then bend the plank in one direction using your preferred method,
i.e. steam/water/leccy plank bender. Then 'dry' test fit.
Repeat the bending if needed.
I will be using the dipping/soaking in hot water method, then the supplied tool for bend.
Then next is to twist the plank to follow the hulls lines. Still dampish plank.
I then will allow to dry and then shape/taper the planks. Using sand paper or small plane.
Test fit again.
Glue at ribs, pin also.
Im going to paint mine and want the copper hull bottom.
Will this work OK or can somebody blow a hole in this plan so i dont in my walletBigGrin BigGrin
This page was generated in 0.119 seconds.
