Hi Andy Looking really good, love the colouring. Paul Building: DelPrado HMS Victory. Building: DeAgostini Sovereign Of The Seas.
 Hi Ian and Paul thanks for looking in and your comments Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Hi All Continued with the lower main mast added the bindings and lower yard sling, made up the maintop, added the blocks and added the stanchions then lastly a coat of Matt varnish. Made a boo boo with the central rubbing strip as its not quite as straight as I thought it was but my excuse is that the constant rubbing from the main yard has caused it to slew to one side. More soon. Regards Andy arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Your certainly pushing on with this one Andy, the mast is coming on very nicely Steve
 Thanks for looking in and your comments steve Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Hi All Made up the Topmast and added the fittings/ blocks as required just the Topgallant and fittings/blocks to add . More soon. Regards Andy arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Blimey Andy you're not hanging around, looking very nice
Great to see it really coming together now Andy, wonderful work as usual.... Regards Alan
 Thanks everyone for looking in and your comments Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Hi All The Topgallant has now been fitted and the various rigging blocks added as per the plan, the mast is taller than I thought it would be but looks great. That concludes pack 25.More soon. Regards Andy arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Hi Andy. The mast on your cross section looks superp. look forward to seeing your progress Ian Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
 Hi Ian, thanks for your comments and looking in Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Joined: 17/11/2012 Posts: 863 Points: 2,608 Location: Gohfeld (Germany)
Hi Andy! A very nice work you made, well done! Regards, Bernd
 Hi Bernd ,Thank you for your kind words Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
