5 Pages <12345>
Budgies Bismark Options
budgie
#41 Posted : 22 April 2015 19:30:35
ian smith wrote:
Hi Budgie.
Looking superp. have you decided which paint scheme you are going to do when you get there. look forward to seeing your progress IanCool Cool BigGrin
Hi Ian i have been thinking (worrying)about which paint scheme to go for
I cannot see myself going for the pattern on the superstructure
Crying Me thinks that will be way out of my comfort zone and capabilities
Possibly 21st May 1941 with the pattern on the hull only
LOL or a few days before they got the paint for that jobFlapper
I am sure there was a period where she had no pattern on the hull or superstructure
Titanic5972
#42 Posted : 23 April 2015 02:20:30
That was the route I took Budgie. Hull pattern only.
On the Go
RMS Titanic 1/250 (third time)
Completed
RMS Titanic 1/250 (twice), DK Bismarck 1/200, RMS Queen Mary 2 1/400, HMS Hood 1/200
#43 Posted : 23 April 2015 13:14:36
Hi Budgie.
I opted for the pattern up to the deck level. I love the false bow and stern waves on the side to give the image of a smaller ship. look forward to seeing more of your build, brings back a lot of memorys off when i was making her. IanCool Cool BigGrin
budgie
#44 Posted : 25 April 2015 11:52:40
BigGrin Mornin' Folks
Have added the "bilge keel" i am more used to calling this part the stabiliser
I used "serious glue" for this part.....once dried i will try and pull it off
They do fall off in real lifeFlapper
HMS Torquay crossing the Bay of Biscay with one stabiliser in a force 10
Crying The only time i got seasick lol
Cool Still several months in Whitley Bay while repairs getting done at Harland n Wolf at Wallsend
budgie attached the following image(s):
#45 Posted : 25 April 2015 13:35:38
Looks great Stuart. It's coming along nicely.Which serious glue then BigGrin I used superglue to stick mine on the only problem with this is you only get one go at positioning it.
Chris
budgie
#46 Posted : 25 April 2015 13:52:26
Chris
BigGrin Hi Chris thanks for popping in
This is the same glue i have used to attach the resin part to wood and it seems solid enough
It is thick and gives you a few minutes to play about with positioning the part
The instructions does say to use epoxy but i would rather use a glue that requires no mixing to save mixing too much or worse not enough for the job in hand
I did think about drilling holes in the "stabiliser" and hull and using brass rod as dowels
1st time i have used this glue on wood to wood but seems solid enough at the moment
Wiil give it a "tap" once fully hardenedLOL
#47 Posted : 25 April 2015 19:38:43
BigGrin Nicely done I usually use the brass pin method myself, still using the belt n bracers methods of old Blink Crying LOL . Looking great with the hull inlets in position too.Cool
#48 Posted : 25 April 2015 23:30:10
Looking good Budgie, very nice indeed....Cool Cool
budgie
#49 Posted : 02 May 2015 10:50:01
Spent the past week adding the rest of the 2nd planking
I did think about using the thinner planks supplied once past the stabilizer area and hope it blends in after sanding but decided to use same thickness as the 1st planking..... hence the dark wood (not enough of light planks to finish)
This will give me a bit off leaway when sanding as i am quite heavy handed and would probably rub thru the thinner planksLOL
Going to rough sand the hull... weather permitting before adding the resin parts and the ply with porthole detail at bow and stern
I have not double planked the top 2 rows of the hull yet will use thin strips for that
Thanks for lookin'
#50 Posted : 02 May 2015 21:05:01
BigGrin Planking looks greatCool
#51 Posted : 02 May 2015 23:32:40
Looking great Budgie, looking at the planking the hull should sand down very nicely..... Well done indeed....Cool Cool
budgie
#52 Posted : 03 May 2015 11:19:34
BigGrin Morning Folks
Crying Nearly got caught sanding indoors as SWMBO returned home earlier than expected
So decide to add resin and detailed ply parts...felt good to finally start seeing some detail appearing
Still got a lot of sanding and tidying up at the joins etc
Progress pics so far...thanks for poppin' in
#53 Posted : 03 May 2015 12:05:19
Loving this build. The shape of the Bismark is remarkable. Your making a great job of the planking and shaping. After sanding down it will certainly please you.
On my Hood for filler to smooth it and blend it all I used Stopper. Which is car filler in a tube used for getting rid of the fine scratches left behind when wet and drying.(Google auto repair stopper filler) Dries pretty quick and is rock solid. Use wet and dry to smooth it.
Hope you don't mind the tip.
Regards Chris
.BigGrin
#54 Posted : 03 May 2015 12:06:12
Looking good Budge, very nice work.....Cool Cool
budgie
#55 Posted : 03 May 2015 15:00:03
Regards Chris
.BigGrin
Hi Chris thanks for the tip
As for "minding" of course not......this is your tried and tested method with great results
I will probably use the wood filler i have already purchased which should cover the 1st going over off the hull just too use it up before purchasing the filler you have reccommended
ps thanks for the post with the picture off the product
http://forum.model-space...amp;m=147089#post147089
#56 Posted : 03 May 2015 15:35:45
Hi Budgie, BigGrin
Looking real good and taking shape fast.
Good pictures as well to show close up detail.
Keep up the good work, I`m enjoying this one for sure.Cool
budgie
#57 Posted : 03 May 2015 18:57:37
BigGrin Cheers Derek
She does look better from a distance...the close up shots shows up any flaws that needs a bit more attention.....bit like somebody i knowFlapper Flapper
Cursing Ouch SWMBO heard thatBlushing Blushing
Still... nothing a good scrub and a couple of layers of filler can't cureLOL
#58 Posted : 03 May 2015 20:13:51
BigGrin Lovely job on the planking m8 Cool keep the pics coming
Rgd martyn
#59 Posted : 03 May 2015 20:24:36
BigGrin Planking looks great and a credit to youCool
budgie
#60 Posted : 04 May 2015 16:34:58
BigGrin Hi Folks .....thanks for taking the time to leave encouragement
Cool covered the hull in filler and been rubbin' away all day OUTSIDE LOL
Crying Sloooooowly getting thereCrying
The pics show some areas where light is shining thru on the 2 upper rows of planks and the squares at the bilge area
But i have still too double plank the upper two rows with a thin veneer and to finish off gauzing the inside off the hull (got bored doing that earlier)
5 Pages <12345>
This page was generated in 0.263 seconds.
