Joined: 14/04/2010 Posts: 44 Points: 78 Location: cardiff
any one no wher i can get some spare woodstrips for the hull if broken most of mine
2x5mm strips.. cornwall models lime stripOn the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
thanks are thay the same ans the magazen
Sorry I'm not sure as I am still waiting for my issues too turn up, But looking at Tomicks build they are definitely 5mm wide as the gunports are 12mm and he cuts away 2 and a bit planks to get it.
Hope that helps.On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
 Rank: Pro  Groups: Registered
Joined: 27/03/2010 Posts: 188 Points: 614 Location: Llandudno
Hi magppie As I am almost defo going to double plank & paint is lime strip the best so as not to show to much grain? Also should I buy & fit the lime strip first, then lay over the Deag strip, or does it matter? Thanks Bob
Hi Bob, Limewood is softwood which doesn't show much grain if sanded with fine grade paper. As for Double planking, you can plank over the Limewood with no problems but you would be better with 1.5mm Planks and the veneer being 1mm thick. The Deag strips are Basswood which is the same as Limewood.
Hope that helps you . Cheers Chris...On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
Joined: 19/03/2010 Posts: 602 Points: 1,679 Location: Lincs
johny5 wrote:any one no wher i can get some spare woodstrips for the hull if broken most of mine http://www.cornwallmodelboats.co.ukYou do not need a parachute to skydive. You only need a parachute to skydive twice.
Built: Golden Star, English Brig. RMS Titanic. (Academy 1/400 Centenary Anniversary Edition) Revell-Monogram 1/48 B-29 Superfortress 1:8 Baron von Richthofen's Fokker Tri-plane. HMS Victory. Nelsons Flag Ship. Sultan Arab Dhow. Artesania Latina Carmen II. The Battleship Yamato. Model Airways Wright Flyer 1:16 Scale. Trumpeter Bismarck 1/200. HMS Sovereign of the Seas. The Black Pearl.
magpie1832 wrote:Hi Bob, Limewood is softwood which doesn't show much grain if sanded with fine grade paper. As for Double planking, you can plank over the Limewood with no problems but you would be better with 1.5mm Planks and the veneer being 1mm thick. The Deag strips are Basswood which is the same as Limewood.
Hope that helps you . Cheers Chris... Thats great mate. But sorry for the noob question.. You say I would need 1.5mm thick planks? What do you meen by veneer being 1mm?
Hi Bob
What I'm meaning is , If you are double planking you would need to forget the deag planks and replace with 1.5mm planks otherwise the ship will be 1mm wider everywhere.
What I mean by veneer, the top layer of plank it being walnut or mahogany etc. It is better to be 1mm thick. any thinner would mean very little sanding...
Hope that gives you the info.. Thanks Chris...On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
Hope that gives you the info.. Thanks Chris... Ah got ya. Nice one. Thanks Chris
Joined: 08/09/2010 Posts: 102 Points: 318 Location: Durban, South Africa
be very with the veneer sanding, I got a little heavy handed with my HMS Endeavour, and went down to the planks. Huge bummer, I ended up having to replace some, and the hull is now a bit patchy in places. I tell myself it is a replica of the repairs done fy the crew when she ran aground on the barrier reef... Part time modeller, full time biker
Built: Pinta Belle Poule (plastic) Endeavour Scratch build of Pirate ship "Neptune" (Based on cutter "HMS Aldebaran" Current builds: Victory
Quintin wrote:be very with the veneer sanding, I got a little heavy handed with my HMS Endeavour, and went down to the planks. Huge bummer, I ended up having to replace some, and the hull is now a bit patchy in places. I tell myself it is a replica of the repairs done fy the crew when she ran aground on the barrier reef... erm, be very CAREFUL with the veneer. BY the crew... (me needs to learn the art of previewing posts...) Part time modeller, full time biker
johny5 wrote:any one no wher i can get some spare woodstrips for the hull if broken most of mine Hi, most hobby shops will stock the appropriate spares. Otherwise, here is an online shop I found, looking for parts for a soon to happen scratch build, it may help. http://www.naturecoast.com/hobby/catalog.htmPart time modeller, full time biker
Just another thing i have just thought. Do I need a veneer if I am going to paint The main reason I am going to double plank is that I am no way confident with my first attempt at planking as this is my first time. And this is to expensive to cock up.  Bob
Im sure you can Bob, but maybe some sanding sealant as mentioned before, see what others reckon.
Zeptrader wrote:Im sure you can Bob, but maybe some sanding sealant as mentioned before, see what others reckon. Thanks for the vote of confidence Colin As you can imagine this is one great wop off learning curve. For something that is probably going to end up costing close to a grand eventualy (as has been mentioned before in other posts) I want to get it spot on. I'd prefer it to look "pre" Trafalgar rather than "post" if you know what I mean. Bob
All you have too remember is take it slow do one plank at a time and check and double check the fit of it first. Then you will have no problems. I had never planked a ship before when I made the San francisco 2 and that one is single planked. My HMS Fly is double planked which will also be my first Double planked.
You can do it if you take it easy Bob. On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
Joined: 17/03/2010 Posts: 301 Points: 941 Location: fife
all my models have been double planked so far, like you i will be double planking the victory as no matter how many ive done (Five) some bits still dont look right with the mistakes i made, so a second planking helps hide these and its neater, i wouldnt think a millimeter or so would make a great difference overall. current builds
