alighnment of slots for stringers of fuselarge Options
Ron
#1 Posted : 27 April 2015 22:03:10
Rank: Amateur Level 1
Hi, have assembled pack 2 and find the slots for the stringers are not in a perfect alignment. Have clamped all together as required, any suggestions ,everything seemed to fit correctly but alignment is not right, help,Ron
michu
#2 Posted : 27 April 2015 22:16:53
Could you please post a photo showing the issue?
Happy building :-)
Ron
#3 Posted : 27 April 2015 22:41:01
Have taken apart rear section of plane to try again to see if can correct item will keep you informed, not yet been able to attached photos as new to the forum ,thanks for your reply regards Ron
#4 Posted : 27 April 2015 23:29:53
Ron, if you go to page 1 of my build you will see that I had an alignment problem as well.
First job was to put a set square across the former to check for alignment and file out the slots, you will find with this build there are some small manufacturing difference at times depends on how the run was set up at the factory, this is what you have to look out for at all times.
hope this is of help to you,
Trev.
This page was generated in 0.032 seconds.
