18 Pages <12345>»
#41 Posted : 04 May 2015 14:15:38
Blimey Alan...Really screaming along with it now!! Love the deck..Was unable to access the other pics for some reason??? Brilliant work mate!!
Wink ThumpUp
#42 Posted : 04 May 2015 19:14:29
BigGrin Hi Jonny thaks for your comments things will slow down a little now the planking has started.
#43 Posted : 04 May 2015 19:39:15
Things are slowing down a little now the planking has started but before I started with the first layer the Bow area had some inserts added just to give some extra support and help with the curve here. I used scrap ply from the kit for the insert so a fair bit of fettling was needed to get it to the right shape and its a trick of the light that make it look like theres a line on the one sideBlink LOL .
So I got 6 planks fitted either side in all but she's starting to look more ship like rather than bones. The build frame has also been made up ready to sit the hull in once the planking is completed. More soon.
#44 Posted : 04 May 2015 19:57:47
You've certainly made some progress on this since I been away, she is really starting to take shape. Awesome work, I love the decking and the effect the wash has given it ThumpUp
#45 Posted : 04 May 2015 22:48:37
You're right Andy, she is looking more and more like a ship with every step you take.. Did the build cradle come with the kit or have you fabricated this one yourself...... Fab work, will be following.....Cool Cool
#46 Posted : 04 May 2015 23:47:47
BigGrin Hi Dave and Alan
Thanks for your comments, The cradle was included with the kit Alan.
#47 Posted : 04 May 2015 23:49:00
wow bored in for a quick look and you have nearly finished!!!!
deck looks superb Andy very authentic
#48 Posted : 05 May 2015 21:33:13
BigGrin Hi Jase Thanks for your comments and looking in, things will slow down now the planking is startingCool
#49 Posted : 06 May 2015 12:27:44
Hi Andy.
Looking superp. certyainly a different shape from the victory. look forward to seeing more of your build. IanCool Cool BigGrin
#50 Posted : 06 May 2015 20:34:10
BigGrin Hi Ian
Thanks for looking in and your comments, there were 7 ships built to this design by the naval architect Sir Thomas Slade of Victory fame. The ships in build order were Ardent, Raisonnable, Agamemnon, Belliqueux, Stately, Indefatidable and Nassau.
#51 Posted : 06 May 2015 22:40:37
BigGrin Hi Ian
Wouldn't it be something to have them all at the same scale in your collection, what a display that would make..... Drool Drool .. Need a dedicated display room though no doubt....BigGrin BigGrin
#52 Posted : 06 May 2015 23:36:01
BigGrin Hi Alan
I agree it would make a great display but thinking of the cost of the extension needed is scary. Personally for me, seeing all seven ships sailing together in real life would have been a sight to remember.Cool
Meanwhile planking continues, now starting to taper the planks at each end. More soon.
#53 Posted : 07 May 2015 07:55:01
Looking great as usual Andy. I find the planking side of it very therapeutic.
Chris
#54 Posted : 07 May 2015 20:10:01
BigGrin Hi Chris
Funilly enough I quite enjoy planking I thinks its because you see a result as you go along and as you watch the gaps to be filled get smaller. Im trying out the recomended way in the instruction for the first time and should only need some stealers at the stern. Its the 1st layer so it get,s covered if I make a hash of itCrying Blink LOL Laugh .Thanks for looking in and your comments.
#55 Posted : 10 May 2015 22:40:00
The first planking is how finished, the hull shape aided the planking only two stealers at the bow per side and around four/five each side at the stern. Next is lots of sanding then the cutting out of the gun port's using the template provided in the plans. More soon.
#56 Posted : 10 May 2015 23:36:55
Finished the first planking layer already Andy..... you're not hanging around are you, I'm wondering if you've slept the last couple of days....BigGrin BigGrin .. Looking great, very well done.... Cool Cool
#57 Posted : 11 May 2015 00:33:12
#58 Posted : 11 May 2015 01:26:21
That must have been some very long days to finish that so quickly.
Good luck with the sanding part of the build. Spent some of the weekend sanding down my Revenge and its amazing just how much sawdust it creates.
Look forward to your next update BigGrin
#59 Posted : 11 May 2015 09:50:27
Wow!! I'm amazed with your progress Andy..She really is taking shape!! Beautiful work!!
Blink ThumpUp
#60 Posted : 11 May 2015 11:27:04
Crickey! That has progressed well, at this rate you will be done by the time I get back from my Holiday BigGrin Cool
18 Pages <12345>»
This page was generated in 0.690 seconds.
