4 Pages <1234>
Marsot Sky Drone Build Options
Marsot
#21 Posted : 06 May 2015 18:05:41
Stage 16 - The first electronic speed control
Marsot attached the following image(s):
______________________________________________________________________________________________
Building: Sky Drone, HMS Victory, Mary Rose
Wishlist: Spitfire
http://www.sotheran.com
Marsot
#22 Posted : 06 May 2015 18:07:02
Stage 17 - Back Left arm cover
Wishlist: Spitfire
Marsot
#23 Posted : 06 May 2015 18:11:57
Stage 18 - Checklist
A summary of my progress in constructing my drone, showing the components assembled so far.
1. Front left rotor arm and rotor guard
2. Right side of body
3. Rear left rotor, rear left rotor arm and left motor
4. Chassis with left side of the undercarriage
Wishlist: Spitfire
#24 Posted : 06 May 2015 19:10:11
#25 Posted : 06 May 2015 22:37:40
Coming along nicely Marsot, well done....Cool Cool
Marsot
#26 Posted : 02 June 2015 17:23:17
Stage 19 - The back left rotor arm
Wishlist: Spitfire
Marsot
#27 Posted : 02 June 2015 17:25:09
Stage 20 - Fixing the right undercarriage
Wishlist: Spitfire
Marsot
#28 Posted : 02 June 2015 17:30:26
Stage 21 - The first clockwise rotor
This was Stage 22 in instructions, but is out of sequence.
Wishlist: Spitfire
Marsot
#29 Posted : 02 June 2015 17:33:28
Stage 22 - The front left motor - fit to front left arm
See note in my Stage 21
Wishlist: Spitfire
Marsot
#30 Posted : 30 June 2015 16:07:21
Supplied Parts Problem
I have had halt my build at Stage 23 - as I have discovered that the Rotor Arm supplied in Part 1of the series was incorrect.
This may be happening to others - therefore please note that Picture 7 on Page 132 of the build instructions clearly indicate that the 'locking system' is situated on the left at the top of the Rotor Arm. The part supplied in Pack 1 of the build was on the right.
I have asked CS for the replacement part.
Wishlist: Spitfire
michu
#31 Posted : 30 June 2015 16:35:43
You might want to check your other rotor arm - at this stage of the build I realised that somehow I had the arms swapped around: rear arm had red rotor guard (and corresponding rotor and red arm panel) installed, and the front one - had the black components. Not sure where I made the mistake but they were switched around.
You can easily check that by looking at the arrows on the first two arms supplied: if they point in the opposite directions, then you have them simply switched around. If the arrows point in the same direction then you indeed have one supplied wrong.
Happy building :-)
Marsot
#32 Posted : 30 June 2015 17:28:11
Thanks for the pointer michu - i'll check first thing tomorrow. Cool
Wishlist: Spitfire
Marsot
#33 Posted : 02 July 2015 17:56:21
Hi Michu, checked and I didn't get them wrong. The part supplied to me in Part 1 was incorrect as previously described.
Thanks for advice though. Hope your build is going well.
Wishlist: Spitfire
longblade
#34 Posted : 07 July 2015 20:14:56
Hi Martin, I have a spare front right/rear left leg if you are interested.. Bob.
Marsot
#35 Posted : 07 July 2015 23:19:20
Hi Longblade, I would be very interested - as I'm getting no response from Customer Support.
How can we handle this. Happy to PM you with me address and somehow arrange for cost of postage.
Martin
Wishlist: Spitfire
longblade
#36 Posted : 08 July 2015 10:30:28
What ever way you would like to proceed,It will only be a couple of P anyway. Get your addy to me and I will get it in the post.. Bob.
Mekon
#37 Posted : 09 July 2015 08:24:09
Rank: Amateur Level 1
Hi All,
I am new to this forum, but joined having become frustrated with Customer Support not responding to me about the error in Pack 1 that some subscribers appear to have suffered. Marsot, I too now have 3 x counter clockwise rotor arms, so the drone will be useless unless I can get CS to respond. I have sent 5 emails to CS now and only received 1 response to the first email saying that some subscribers had received incorrect parts, but to date no replacement. First communication was sent 2 months ago now. At this stage, I would almost give up the build, but as I opted for the 12 month option, it would be a large amount of money down the drain and all I would have is an expensive paperweight.
By the way, there are some really nice looking builds here, and I hope that the rotor arm issue can be sorted because the drone does look great fun when complete.
Marsot
#38 Posted : 09 July 2015 09:28:29
Hi Newbie,
I have to share your view about Customer Services - they do not respond adequately and rarely tell you what exactly is happening to your problem.
I would suggest you Private Message 'Tomick' who seems to be able to get things done and more than anyone else understands the models, as he has built them. But he will only get involved if you have given CS a fair time to do their thing.
Wishlist: Spitfire
#39 Posted : 10 July 2015 11:40:29
Anyone that has an incorrect arm for Pack 1, can you send me a PM with your account number and address detail, so that a correct replacement can be provided.
Thanks
Mekon
#40 Posted : 10 July 2015 21:36:00
PM sent Tomick. Many thanks for your help.
4 Pages <1234>
This page was generated in 2.539 seconds.
