Something many modellers do is pack the bow formers out with balsa wood and then shape when rubbing down. The planks will then lay better.
I can't remember which diaries show this but someone may pop up hopefully.
Certainty something I will do next time.
Hi Dominick, it looks to me like you have added the shims between former 8 and the keel. Do not glue these in position as they are not needed. Further into the build there are two ply fillets that fit in between former 8 and the keel so if you glue the shims there then you'll have problems fitting the ply inserts.  .. Otherwise everything is looking good so well done..... Regards Alan
 Rank: Pro  Groups: Registered
Joined: 25/04/2015 Posts: 154 Points: 462 Location: Northern California, USA
Alan, Thanks, you may have just saved my bacon as the expression goes. I will not glue them but leave them press fitted for now to keep the keel straight until I get the fillets. Thanks again. Dominick
On the Bench: DeAgostini HMS Victory, Moebius Creature From The Black Lagoon Up Next: We'll See
DSoldano wrote:Alan, Thanks, you may have just saved my bacon as the expression goes. I will not glue them but leave them press fitted for now to keep the keel straight until I get the fillets. Thanks again. Happy to be of help Dominick, think now you can already see the positive aspects of keeping a build diary, it allows us to perhaps prevent some of the potential mishaps before they happen. Keep it going, I'll be watching all the way..... Regards Alan
Ok, I completed the planking jig for the first of the ship's boats today. It all came out nice and square and is looking good. I am waiting for the CA to fully cure before I sand down the frames to fair it. I test fitted a plank to the jig and it seems as if the shoulders on frames 9 and 12 are a little high by about 1 mm to 1.5 mm. When I put the plank on it sits on the ledge of those two formers (both sides) and is up off of the others by the difference in height. I assume I should level those two with the others as part of the fairing process, is that correct? DSoldano attached the following image(s): Dominick
And here's the top view. Now on to the cannon while this dries. DSoldano attached the following image(s): Dominick
z8000783 wrote:Something many modellers do is pack the bow formers out with balsa wood and then shape when rubbing down. The planks will then lay better.
Certainty something I will do next time. John, Thanks. I have seen that in a few articles and books I have read. I will look into it once I see about the fillets that get installed. Dominick
Hi Dominick, I would reduce the shoulder height on both those ribs to bring the first planking row into line. When you do this and when you fair the ribs, do this very gently as the ribs are very fragile. Take your time with it... Regards Alan
Alan, Thanks. Will do. Dominick
I started on the first of the ship's guns - a cannon. I notice in the official build diary that these get pinned to the deck later on. Given that, is it best to drill the holes for the pins now, when pinning them, or perhaps to glue them with a little CA instead of using pins? Also, how far in should the wedge be inserted - basically, at what angle to horizontal should the gun be to properly/realistically align with the gun ports? DSoldano attached the following image(s): Dominick
First of what I expect will be many cannons completed in Trafalgar colors. DSoldano attached the following image(s): Dominick
Frames for the ship's boat faired. I hope to apply the first of the planks this afternoon. DSoldano attached the following image(s): Dominick
Hi, Some nice work there  I used CA glue to fit my cannons rather than pins, just semed easier. The wedge / gun angle on mine puts the gun barrell practically horizontal, this seems to match my gunport lower edge just right, btw there are 16 fully rigged cannons plus 2 stowed at the bow Steve
Steve, Thanks. I've looked at your builds as well, amazing work, certainly something for me to aspire to. I think I will glue them as well. Seems silly to risk damaging them by drilling holes and pushing in pins. I imagine each wedge may come out slightly different so I may store them all with the cannons and glue them in as the cannons are mounted on the deck. This way I can probably keep them all consistent. I hand painted this one, not too bad, but I think in the future I may wait until I have a few and airbrush them in a batch. Dominick
Hi Dominick glad you have put up a build diary and you've made a great start, but the most important question about it is what single malt are you drinkaling while building The Royal Navy's flagship ? could it be a Jura, a singleton, an Aberlour ? Regards Paul Building: DelPrado HMS Victory. Building: DeAgostini Sovereign Of The Seas.
Gibbo wrote:Hi Dominick glad you have put up a build diary and you've made a great start, but the most important question about it is what single malt are you drinkaling while building The Royal Navy's flagship ? could it be a Jura, a singleton, an Aberlour ? Regards Paul Paul, Thanks. It's one of my favorites, Oban, an Islay - I also like Laphroig, the smokier and peatier the better. Dominick
Joined: 14/04/2015 Posts: 238 Points: 716 Location: Newcastle
Great start so far, I really like the cannon.
You're doing a great job Dominick, lovely work.... Regards Alan
 Some nice work there and well done Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Gents, Thanks for the kind comments. I made a little more progress today. Cut the channel in the anchor stock and glued the halves together and eased the corners. I still need to round the ends as shown in the official build log. Right now the anchor isn't glued in it's just press fit. I figure it will be easier to complete the stock first and then glue the anchor in. I plan to go the heavy paper route as I think it will look more like iron banding than the thread. We have some nice heavy stock at work and a wheel type paper cutter that will give some nice, thin, even strips. Even though the stock was painted black at Trafalgar, I just think the walnut looks way too nice contrasted with the black - so the walnut stays. More to come DSoldano attached the following image(s): Dominick
Guest (10)
