13 Pages <1234>»
Dominick's Build Log Options
z8000783
#21 Posted : 08 May 2015 17:35:24
Groups: Unapproved
Something many modellers do is pack the bow formers out with balsa wood and then shape when rubbing down. The planks will then lay better.
I can't remember which diaries show this but someone may pop up hopefully.
Certainty something I will do next time.
#22 Posted : 08 May 2015 18:55:39
Hi Dominick, it looks to me like you have added the shims between former 8 and the keel. Do not glue these in position as they are not needed. Further into the build there are two ply fillets that fit in between former 8 and the keel so if you glue the shims there then you'll have problems fitting the ply inserts. Cool Cool .. Otherwise everything is looking good so well done.....
DSoldano
#23 Posted : 08 May 2015 18:58:40
Alan,
Thanks, you may have just saved my bacon as the expression goes. I will not glue them but leave them press fitted for now to keep the keel straight until I get the fillets.
Thanks again.
BigGrin
Dominick
On the Bench: DeAgostini HMS Victory, Moebius Creature From The Black Lagoon
Up Next: We'll See
#24 Posted : 08 May 2015 19:25:30
DSoldano wrote:
Alan,
Thanks again.
BigGrin
Happy to be of help Dominick, think now you can already see the positive aspects of keeping a build diary, it allows us to perhaps prevent some of the potential mishaps before they happen. Keep it going, I'll be watching all the way.....
DSoldano
#25 Posted : 09 May 2015 00:57:02
Ok, I completed the planking jig for the first of the ship's boats today. It all came out nice and square and is looking good. I am waiting for the CA to fully cure before I sand down the frames to fair it. I test fitted a plank to the jig and it seems as if the shoulders on frames 9 and 12 are a little high by about 1 mm to 1.5 mm. When I put the plank on it sits on the ledge of those two formers (both sides) and is up off of the others by the difference in height. I assume I should level those two with the others as part of the fairing process, is that correct?
DSoldano attached the following image(s):
Dominick
Up Next: We'll See
DSoldano
#26 Posted : 09 May 2015 00:59:10
And here's the top view.
Now on to the cannon while this dries.
Dominick
Up Next: We'll See
DSoldano
#27 Posted : 09 May 2015 01:10:10
John,
Thanks. I have seen that in a few articles and books I have read. I will look into it once I see about the fillets that get installed.
Dominick
Up Next: We'll See
#28 Posted : 09 May 2015 01:17:08
Hi Dominick, I would reduce the shoulder height on both those ribs to bring the first planking row into line. When you do this and when you fair the ribs, do this very gently as the ribs are very fragile. Take your time with it... Cool Cool
DSoldano
#29 Posted : 09 May 2015 02:05:22
Alan,
Thanks. Will do.
Dominick
Up Next: We'll See
DSoldano
#30 Posted : 09 May 2015 05:50:16
I started on the first of the ship's guns - a cannon. I notice in the official build diary that these get pinned to the deck later on. Given that, is it best to drill the holes for the pins now, when pinning them, or perhaps to glue them with a little CA instead of using pins? Also, how far in should the wedge be inserted - basically, at what angle to horizontal should the gun be to properly/realistically align with the gun ports?
Dominick
Up Next: We'll See
DSoldano
#31 Posted : 09 May 2015 17:34:29
First of what I expect will be many cannons completed in Trafalgar colors.
Dominick
Up Next: We'll See
DSoldano
#32 Posted : 09 May 2015 17:38:46
Frames for the ship's boat faired. I hope to apply the first of the planks this afternoon.
Dominick
Up Next: We'll See
#33 Posted : 09 May 2015 17:46:02
Hi,
Some nice work thereBigGrin I used CA glue to fit my cannons rather than pins, just semed easier.
The wedge / gun angle on mine puts the gun barrell practically horizontal, this seems to match my gunport lower edge just right, btw there are 16 fully rigged cannons plus 2 stowed at the bowBigGrin
DSoldano
#34 Posted : 09 May 2015 18:21:13
Steve,
Thanks. I've looked at your builds as well, amazing work, certainly something for me to aspire to.
I think I will glue them as well. Seems silly to risk damaging them by drilling holes and pushing in pins. I imagine each wedge may come out slightly different so I may store them all with the cannons and glue them in as the cannons are mounted on the deck. This way I can probably keep them all consistent.
I hand painted this one, not too bad, but I think in the future I may wait until I have a few and airbrush them in a batch.
Dominick
Up Next: We'll See
Gibbo
#35 Posted : 09 May 2015 20:25:30
Hi Dominick
glad you have put up a build diary and you've made a great start, but the most important question about it is what single malt are you drinkaling while building The Royal Navy's flagship ? could it be a Jura, a singleton, an Aberlour ?
Paul
DSoldano
#36 Posted : 09 May 2015 22:03:53
Gibbo wrote:
Hi Dominick
Paul
Paul,
Thanks. It's one of my favorites, Oban, an Islay - I also like Laphroig, the smokier and peatier the better.
Dominick
Up Next: We'll See
michael.rolph
#37 Posted : 09 May 2015 23:24:52
Great start so far, I really like the cannon.
#38 Posted : 09 May 2015 23:53:50
You're doing a great job Dominick, lovely work....Cool Cool
#39 Posted : 10 May 2015 00:01:58
BigGrin Some nice work there and well doneCool
DSoldano
#40 Posted : 10 May 2015 02:05:25
Gents,
Thanks for the kind comments.
I made a little more progress today. Cut the channel in the anchor stock and glued the halves together and eased the corners. I still need to round the ends as shown in the official build log.
Right now the anchor isn't glued in it's just press fit. I figure it will be easier to complete the stock first and then glue the anchor in. I plan to go the heavy paper route as I think it will look more like iron banding than the thread. We have some nice heavy stock at work and a wheel type paper cutter that will give some nice, thin, even strips.
Even though the stock was painted black at Trafalgar, I just think the walnut looks way too nice contrasted with the black - so the walnut stays. BigGrin
More to come
Dominick
Up Next: We'll See
Guest (11)
13 Pages <1234>»
This page was generated in 0.464 seconds.
