neon Options
neon
#1 Posted : 12 May 2015 14:47:43
Can anyone help me. On issue 46 I have set about making the gratings fir the third deck. There is only ine bag of gratings supplied with my issue which is enough for one grating. The instructions suggest I maje the two gratings in this issue but there us nit enough supplied. Has there been a mustake here ?
#2 Posted : 12 May 2015 17:00:51
Hi Neon, BigGrin
I have had a look at the official build to try and help you.
From what I`ve read in the issue 46 section, it says that you need to use grating parts for the second grating from the ones issued in part 44.
Hope this helps.
neon
#3 Posted : 12 May 2015 17:08:15
Thanks del boy. That leaves me screwed then as I have no more gratings. What can I do here ? Can I buy more ?
#4 Posted : 12 May 2015 17:16:29
Hi neon, BigGrin
If you`re sure you have none from issue 44, then can only assume they were missing from your pack.
If you contact customer services, they may be able to help.
#5 Posted : 12 May 2015 17:54:12
Hi Neon
You can always get more gratings from any model boat supplier (in case you break any along the way)
I use Cornwall Model Boats which you'll often see mentioned in the members diaries (usually as CMB) Just put their name into the browser and you'll get their website. Don't forget to measure the ones you need, they come in different sizes!
Best of luck.
#6 Posted : 12 May 2015 18:56:28
Hi Neon, just read your post and I may be able to assist you here. I changed all the gratings on my build as I wanted to fit a smaller scale. I think I still have the gratings supplied and if so then I'd be happy to send FOC... Let me check first and get back to you later this evening.... Cool Cool
neon
#7 Posted : 12 May 2015 20:15:44
Hi alan.
That is very very nice of you. If it's possible I would be most delighted. Gratings are not my speciality. I made up the first one and when I put it in the deck I just wasent happy if you can understand. I am going to start over. If you have any gratings I can use I would be sincerely grateful.
#8 Posted : 12 May 2015 20:29:40
Hi Neon, I've just checked in my spares box and I do in fact have a set of gratings you can have... PM me your address and I'll see if I can get them mailed to you this week.... Hope this helps...
This page was generated in 0.647 seconds.
