6 Pages 123>»
My Jupiter Build Options
GilShapley
#1 Posted : 01 May 2015 18:21:14
Done Planes
Done Boats
so it must be trains next.
Was looking at the D51 but wanted something that I could finish a little quicker.
Have been following Darbyvets Occre Build of the Jupiter.
Reminds me of all those Westerns that where on the telly pre SciFi times
Have now received my kit from Cornwall Models and so too start
Step 1) Check contents of Box. If the weight of the box is an indication I think this will be a good quality kit.
Will post pictures as I progress
Current Build:-
#2 Posted : 01 May 2015 18:58:06
Excellent-another Jupiter build.Look forward to seeing you build diary Gil.
Everything has been smooth sailing so far except for the construction of the tender.I built my wood frame for the tender and then noticed it was warped so be careful when you build that.Everything fits so well I got a little complacent.
#3 Posted : 01 May 2015 19:16:08
Nice kit Gil, will you be entering yours into the 'Build of the Year' comp as well? I think Darbyvet has entered his? Cool ThumpUp
#4 Posted : 01 May 2015 20:13:19
BigGrin Hi Gil , Looks a nice little kit and I will look forward to your build diaryCool
#5 Posted : 01 May 2015 22:22:36
Awesome, another Jupitar. Look forward to seeing your progress
#6 Posted : 01 May 2015 23:42:29
Good luck with your build Gil, hope to follow your progress...Cool Cool
GilShapley
#7 Posted : 05 May 2015 19:57:08
Having now completed my inventory of the box the build begins
The parts consist of metal, plastic and wood
The plans/instructions are exploded diagrams showing what goes where so that should be fun
I intend to follow the plans as set out A to B to C etc with the only deviation where I think it might be easier to complete the painting of some parts prior to construction
I have noticed that some of the plastic parts will require some easing to fit and care will be required as they are fragile in some areas.
Some pictured added and more to follow as the build progresses
Current Build:-
#8 Posted : 05 May 2015 21:43:42
BigGrin Nice start GilCool
GilShapley
#9 Posted : 07 May 2015 16:25:26
I have decide to move away from my original plan to follow the build as per the plan order and will now be building various components of the build to be assembled into a complete engine later. My next step is the Cow Catcher for the front of the engine.
Straight forward if a bit fiddly and some careful sanding of some of the component to ensure a good fit
Have primed this ready for the final painting later
Current Build:-
GilShapley
#10 Posted : 09 May 2015 15:36:45
The Build Continues
The Framework for the Boiler
and
The Drivers Cab framework now completed
Pictures attached
Current Build:-
#11 Posted : 09 May 2015 23:27:48
Lovely work Gil, great start you've made....Cool Cool
#12 Posted : 10 May 2015 01:26:53
super work so far.
GilShapley
#13 Posted : 10 May 2015 10:27:54
Thanks for the positive comments
Have decided to have a go at the wheels. Was not to sure of the colour or what paint to use.
In the end I primed with modelmates grey primer and use Halfords Peugeot Cherry Red (Yes that's a car spray from my local car parts store) You get twice as much paint for the same price as hobby paint.
I have not finished yet as you will see in the picture. the masking is still on the rims. I will remove and buff the base metal to give a nice shine, hopefully
Current Build:-
#14 Posted : 10 May 2015 11:18:33
Gil
Cracking build you have on the go there.
The instructions look to be a lot better than what i have in the Adler kit. They seem to have gone the route of the teaditional plastic model kits with the jupiter ones and they look easier to follow to my eye.
Good call on the halfords paint by the way it really is good indeed and the under coats they do are very good quality. Been doing some advance planning (a long way off as yet) for a Titanic build and the red primer gets recommended as one of the best choices for the anti fouling psint on the lower hull.
The "appliance" white spray they do is also a good choice for a whole host of space related models.
Looking forward to your next updates.
GilShapley
#15 Posted : 10 May 2015 12:01:55
Thanks for that
When I built my Model of the Bismark some years ago now I used Halfords red primer for the hull (Below the water line) which is one of the reasons I went back to them for the paint on this build
BigGrin BigGrin BigGrin BigGrin BigGrin BigGrin BigGrin
Current Build:-
GilShapley
#16 Posted : 12 May 2015 19:09:16
Have now finished the Cow Catcher
I used French Blue as I had some left over from my Victory Build
The six Brass pins are also from the Victory as I preferred the colour to those supplied. In view of their length I cut them down to 4mm and pre drilled the base of the cowcatcher to received the cut-down pins. As a lot of this build is MDF pre-drilling is I feel recommended to avoid splitting
Current Build:-
#17 Posted : 12 May 2015 20:12:28
Looking good Gill Cool
I have a Titanic waiting to be done so thanks to you and Tony I will taking a look at the Halfords primer for the anti fouling BigGrin
#18 Posted : 12 May 2015 23:39:11
Very nice Gil, she's going to be a fabulous display piece when done.....Cool Cool
ALan
#19 Posted : 13 May 2015 19:04:15
Hi cracking build you have there looking really smart.like the old western locos a lot.look forward to seeing more.cheers mick.BigGrin BigGrin
GilShapley
#20 Posted : 14 May 2015 10:23:00
I have decided to complete as far as I can all the wooden shells before I add the metal coverings.
One thing I have found is that it is important to dry fit the components as some of them require some sanding to obtain a good fit. Being MDF too much pressure can result in damage followed by bad language !!!!!!!
Mad Mad Mad Mad
Just finished the first part of the tender
I see from the plans that I will be required to mark the rivets on the metal covers and to that end I have purchased a pounce wheel. Never used one of these before so it will be a learning curve. Any advice on the methodology for using this implement will be gratefully received
Confused Confused Confused Confused
Current Build:-
Guest (10)
6 Pages 123>»
This page was generated in 0.267 seconds.
