Joined: 10/10/2010 Posts: 691 Points: 2,136 Location: Dorset
I am at present building the Jupiter Model Train. You may have seen these trains in a western usually being chased by outlaws or Indians. The metal sheeting used to cover the wooden frames requires me to use what I think is called a Pounce wheel, this looks a bit like spurs worn by cowboys which is apt for the model I am building Having never used one of these any advice would be welcome Current Build:- [color=blue]Stash Avro Lancaster (Full Kit)plus some extra issues I picked up at a good price [color=blue]Built:- Norman Catapult by Mantua,Roman Catapult by Mantua,HMS Victory,HMS Victory XSection,Focker DB1,Bismark,English Carronade Titanic Lifeboat,American Civil War Gatling,Hummer,Sopwith Camel F1,Occre Jupiter ,OcCre Wagon, Latina Arab Dhow, Eaglemass Orrery OcCre Rogers 119 [color=red][color=red]RB7,OcCre Missippi River Boat, Model Airways Fokker DR1 OcCre London L>C>C 106 Ugears Scrambler, Ugears Hexapod Explorer UGears Off-Road Vehicle
Hi Gil, The Spitfire build uses a pounce wheel for exactly the same thing. If you refer to section 57 of the official build it gives you a run through of what to do. Hope this helps. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Run the tool along a steel rule to get a good straight edge. You also need to choose a wheel which has the correct pitch for the scale you are working in, otherwise the rivets could be too small or too large.
If you want raised rivets, the the underside of the sheet is the side to rol it over, if you want sunken rivets, roll it over the top side.
Trumpeter make a rivet making tool http://www.emodels.co.uk...-rivet-maker-09910.html
Also this set on Amazon http://www.amazon.co.uk/..._aui_detailpage_o09_s00
Now that's what I call service Question posted @ 13.18 1st response 13.31 2nd response 13.34 Many thanks Gil Current Build:- [color=blue]Stash Avro Lancaster (Full Kit)plus some extra issues I picked up at a good price [color=blue]Built:- Norman Catapult by Mantua,Roman Catapult by Mantua,HMS Victory,HMS Victory XSection,Focker DB1,Bismark,English Carronade Titanic Lifeboat,American Civil War Gatling,Hummer,Sopwith Camel F1,Occre Jupiter ,OcCre Wagon, Latina Arab Dhow, Eaglemass Orrery OcCre Rogers 119 [color=red][color=red]RB7,OcCre Missippi River Boat, Model Airways Fokker DR1 OcCre London L>C>C 106 Ugears Scrambler, Ugears Hexapod Explorer UGears Off-Road Vehicle
HI Gil, I have a pounce wheel and tried using it to make rivets on the Jupiter, but the metal is quite thick and a bit stiff and it was difficult to get good results.It would also be really tough to do that on the chimney since you will probably need filler and sanding to get the chimney smooth and that would affect the rivets you made in those pieces. I decided to go for decal rivets.I have used these before and they are really easy to apply and look great. I got mine from micromark http://www.micromark.com...archPhrase=rivet+decals
You build looks great so far BTW
Now this is an interesting conversation... I have been looking at one of these for adding rivet detail to the funnels on my HMS Warrior whwn i get around to her. http://www.metalsmith.co...ivet-embossing-tool.htm
Jase “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
Nice find Jase, may be worth sharing this one in the tools section.... Thanks for sharing.... Regards Alan
Gandale wrote:Nice find Jase, may be worth sharing this one in the tools section.... Thanks for sharing.... Regards Alan Hi Alan, Thanks for raising that idea, my personal feeling is that if i put it in the tool section it may get seen as a recommendation, so i only tend to put things in there i have tried and tested, i have niot fully decided on this one yet as i can see advantages and disadvantages but certainly looks a good option for thicker material. Jase “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
The big disadvantage appears to be that you would need to be perfect with the rivet spacing of each rivet, which could drive you nuts!
