captain cooks THE HM ENDEAVOUR Options
benny
#1 Posted : 10 September 2010 15:20:36
WILL BE POSTING SOME PICS AS SOON AS I HAVE SORTED IT OUT...WATCH THIS SPACECool
cheers benny
benny
#2 Posted : 18 September 2010 11:23:22
ok sorted it out and made a start.plans are a little vague but i am sure i will get there..anyway i have put her in a jig and installed the ribs
cheers benny
benny
#3 Posted : 18 September 2010 11:25:46
next is the decks and the start of the first planking she is double planked so any mistakes can be sorted
cheers benny
Jack Sparrow
#4 Posted : 18 September 2010 11:28:47
Looking good so far BennyCool BigGrin . What is the quality of the kit like?BigGrin BigGrin
benny
#5 Posted : 18 September 2010 11:32:05
hi jack first impressions are not that good but i am determined to get this one spot on..the ribs are not cut properly so i had some packing and shaping to do to get both sides the same
cheers benny
Jack Sparrow
#6 Posted : 18 September 2010 12:06:43
Well your in the right place for help, hints and tips!!! Good luck and keep the pics coming!!BigGrin BigGrin Cool
#7 Posted : 18 September 2010 12:16:05
Looking good so far Benny, and I agree with you about hiding any mistakes with the secondary planking, I had to totally rebuild the stern of the Cutty Sark, the secondary planking hid the changes perfectly. Good luck on your build and keep us posted...
ThumpUp
benny
#8 Posted : 18 September 2010 12:29:55
i have built the stand and added more first planks
cheers benny
benny
#9 Posted : 18 September 2010 12:31:17
i decided to add balsa fillers to the bow
cheers benny
benny
#10 Posted : 28 September 2010 20:14:06
now the first planking..this is a mamoli build and i am pleased to say.thank god its double planked,what a nightmare.. as you can see i added darker planks and also extra planks from my other builds leftovers, the planks supplied did about 2 thirds and i used every piece apart from a few inch long off cuts..not good,anyway in the end all i was interested in was getting it planked,not pretty but its even both sides..i have covered it in 2 part filler and sanded it down and i now have a very good base for final planking totally even and sound ,this wont be painted or stained just oiled
cheers benny
Jack Sparrow
#11 Posted : 28 September 2010 20:39:39
Looking good.BigGrin
benny
#12 Posted : 28 September 2010 23:17:49
in the instructions it says the whales are applied first..i have done the first whale and a few of planks which i have caulked...is this a good idea to caulk the planks on the hull? i also plan to apply a nail finish to the planks any thoughts would be appreciated
cheers benny
benny
#13 Posted : 30 September 2010 20:29:47
i have found this picture so i wont be oiling it now i will paint it as close to this as i can
cheers benny
benny
#14 Posted : 23 October 2010 14:30:38
i have now second planked the hull and as i am now painting i have filled with 2 part filler and given it a good sand down and filled again with fine filler, with that sanded i have given it a coat of white paint to show up any imperfections that need sorting
cheers benny
jay7792
#15 Posted : 25 October 2010 19:16:43
Looking good mate, if the hull planking on my mamoli victory turns out even half as good as this I will be very happy.
I know what you mean with regards to the shortage of wood, looks like I'm in the same boat!!
_____________________________________
Currently building:-
Deagostini HMS Victory
Amati Black Pearl
Mamoli HMS Victory 1:90 Scale
Caldercraft HMS Victory 1:72
benny
#16 Posted : 25 October 2010 20:22:53
i have wrestled with this since i started..are all mamolis like this..i started to plank the decks today and guess what..not enough planks..this will be going in the bin soon
cheers benny
benny
#17 Posted : 26 October 2010 10:46:51
i have planked the top deck using the 3 plank stagger and gave it a coat of oil
cheers benny
This page was generated in 0.142 seconds.
