5 Pages <1234>»
Malc's M23 - James Hunt Options
RM1
#21 Posted : 16 May 2015 06:24:32
I left the exhaust pipes on their moulding sprues for painting ( and to not lose track of their part numbers BigGrin ).
I used an undercoat of gloss black and then Alclad 2 stainless steel.
RM1
#22 Posted : 16 May 2015 06:35:01
The anti-roll bar was a bit tricky to position as it didn't have a "snap' in location. I found the best way was to hold the gearbox suspension assembly upside down.
ian2014
#23 Posted : 16 May 2015 21:43:54
The skill that has gone into this amazing and a lot of time keep up the good work.
Facebook-model maker
#24 Posted : 16 May 2015 23:08:56
BEAUTIFUL!! You can see the love and attention you are putting into this, it is going to be fine looking model when finished Cool
RM1
#25 Posted : 23 May 2015 16:25:02
Making a start on the bodywork. Quite a lot of mould lines to smooth out. Also removing the front wing end plates to fit the PE parts.BigGrin
RM1
#26 Posted : 23 May 2015 16:36:07
The airbox is two parts so quite a lot of filling and polishing.
RM1
#27 Posted : 23 May 2015 16:50:18
This is the first time that I have had to do a visible line between two colours. I sprayed the white first and then the red (tamiya TS36 Fluorescent red)Pleased with the result but a little bleed of red on the underside. Must be more positive with the masking tape.BigGrin
mark8454
#28 Posted : 24 May 2015 10:38:56
Amazing work!!
RM1
#29 Posted : 14 June 2015 16:22:00
It's not all good news, got a bit over enthusiastic with spraying the rear wing endplate. Have to rub it down and start again.
RM1
#30 Posted : 14 June 2015 16:25:59
Mark's great progress with his build has inspired me to get some more done on this build. A major masking job and spraying the TS36 red. A couple of glitches but pleased with the result.BigGrin
RM1
#31 Posted : 14 June 2015 16:31:03
Also sprayed the red line that runs along the base of the bodywork. have to do that with the underpan moulding next. Couldn't resist putting the parts together to see how it looks.BigGrin
Malc.
Warthog
#32 Posted : 14 June 2015 18:32:36
Looking great Malc Cool So much fun doing the older F1 cars and the temptation of putting them together before complete is half the fun BigGrin
Spencer
mark8454
#33 Posted : 14 June 2015 18:43:19
This is awesome!!
One reason I didn't attempt the 1:20 is the pure skill needed to implement such detail, something you have done fantastically, pure inspiration for my build!
#34 Posted : 14 June 2015 20:59:36
BigGrin Now that looks soooooooooo sweetCool
RM1
#35 Posted : 15 June 2015 09:33:48
Thanks to all for looking in and giving the supporting comments. There's great scope for detailing around the engine and suspension on these older F1 cars and you can see it even when the body is in place !! BigGrin
Nice to see three James Hunt builds on the go in this forum. Giving me lots of ideas for mine.
RM1
#36 Posted : 16 June 2015 16:27:03
Some more masking to spray the red line along the base of the body.
#37 Posted : 16 June 2015 16:57:19
BigGrin SWWEEEEEEEEEEEEEEETCool
#38 Posted : 16 June 2015 18:07:46
Nice work Malc, that red cheatline looks very tricky to mask but you did a great job of keeping it neat and straight, well done. Cool ThumpUp
#39 Posted : 16 June 2015 22:07:29
Great work Malc ThumpUp
RM1
#40 Posted : 17 June 2015 15:16:00
Thanks Kev.
I had to google "cheatline" LOL but pleased to learn something new.BigGrin
Malc.
5 Pages <1234>»
This page was generated in 0.083 seconds.
