Hi All, Thanks to Alan and Dave for looking in, sorry to hear of the delays Alan. So on to stage 5: Parts you get as follows; Back panel Cooling fan and guard 4x M3 screws, washers and nuts. As these panels are to be stored for a while, I`ve decided to leave as much protective backing on for as long as possible. Orientate the back plate as shown with the circular hole bottom left and the square hole bottom right. You now have to fit the fan guard. Make sure that the guard is fitted the correct way round. The guard shape should come out towards you and not protrude into the hole. Place four M3 screws into the holes. Now lift the back plate, hold the four screws in place and turn the back plate over. Fit the fan onto the four screws making sure that the fan wiring is in the position shown below. Now fit an M3 washer and nut to each screw and tighten the screws in the order shown in the instructions. This is where you are at the end of stage 5 Now on to stage 6: The parts; Noise filter (mains input socket) 2 x M3 screws, washers and nuts. These parts fit into the back plate that had the fan fitted in stage 5. I removed a small amount of protective paper and made sure that the noise filter is set the right way round. The two M3 screws, washers and nuts are now fitted to hold the noise filter in place. At the end of stage 6, you back plate should look like this. (With or without the protective paper, is your choice) Stage 7: The parts; Limit switch circuit board 2 x spacers 2 x M3 screws, washers and nuts. You need to orientate the back plate that has the fan and noise filter fitted, as per the instructions. Remove the protective paper, if not already done. Then place the two spacers over the holes to be used. Now place the circuit board onto the spacers, with the pins pointing in the direction indicated by the red arrow. Then insert the two screws supplied, indicated by the two blue arrows. Holding the two screws in place, turn over the back plate and fit a washer and nut to each screw, then tighten just enough to hold the circuit board in place. At the end of stage 7 your back plate should look like this: Well that`s it, pack 2 is now completed. Just needed to pack the parts away carefully, so used the vastly improved packing that came with pack 2. Now waiting for pack 3 to arrive. Happy building Regards delboy271155 (Derek) delboy271155 attached the following image(s): COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
 Rank: Semi-Pro Level 1    Groups: Registered
Joined: 17/11/2015 Posts: 60 Points: 183 Location: USA
Really fun and informative to read through. I get a good look at what I have to look forward to! JC
AgentReverie wrote:Really fun and informative to read through. I get a good look at what I have to look forward to! JC Hi JC, Thanks for looking in and happy you enjoyed the diary. Have completed some more of this kit, but not posted as yet. (hope to do so soon) Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
 Nice to see you back on this one Derek Rgd Martyn Building ? Completed. Soliei Royal . Sovereign of the Seas . Virginia . Scotland . San Felipe . Corel vasa , Santisima Trinadad X section , Vasa Next Build ? When sailors have good wine, They think themselves in heaven for the time. John Baltharpe
Hi All, Update:I have actually completed this build up to pack 8, (awaiting delivery of pack 9). So thought I`d better get some updates on. I restart with pack 3 / stage 8. Add the Z-axis limit switch and a reinforcing plate.The first pic shows the parts for stage 8. Assemble the switch, two screws and two spacers as shown. The limit switch fits just above the noise filter on the inside of the back panel. It must be positioned so that the connector tags are pointing to the left. Holding the parts in place turn the panel over and fit two washers and nuts to hold the switch in position. Do not fully tighten the nuts as the switch will have minor adjustment at a later stage. tighten just enough to hold in place. You may have noticed that I have now removed all the protective covering of the back panel. Reason is that now a reinforcing plate is fitted in the centre of the panel. Remove the covering from the reinforcing panel, put the four remaining screws in the holes and put the reinforcing panel in position on the outer face of the back panel. Hold the parts in place, fit a washer and nut on each screw and tighten finger tight with a screwdriver. The final picture shows stage 8 completed. delboy271155 attached the following image(s): COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Hi All, "AMENDMENT"An amendment comes up in pack 6, that if you are not already past this point in your build is more easily accomplished at this point.(Not difficult if your past this point, just a bit more fiddly). In stage 5 we fitted a cooling fan. The instructions said to fit the fan with the wires at the Top Right position. This has been amended to the Bottom Right. See picture below. Red arrow = old position Blue arrow = new position. PLEASE NOTE:In a future post, with thanks to AgentReverie, he pointed out that I did not have the fan seal facing the fan grill. That has now been amended. (See second picture below). I have left the first picture on here so you can see the difference. delboy271155 attached the following image(s): COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Hi, Stage 9 Enclosure assemblyFirst pic shows parts supplied. Now, there are 22 steps in the next part of this build. The instructions are extremely precise and the pictures are excellent and I`m not going to duplicate them here. What I will say is, follow the instructions by the letter, it may be easier to have another pair of hands available (like SWMBO ),but not essential. Note: DO NOTfully tighten the nuts and bolts as in stage 10 a jig/top plate is fitted that squares everything up prior to tightening. So the enclosure is assembled.(See pic) That concludes Stage 9. delboy271155 attached the following image(s): COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Hi Stage 10 Fit the assembly jig and tighten the nuts and bolts.As with stage 9, I suggest you follow all the steps in the instructions, in the order given. (The instructions give far better pictures than I can  ) Note: Be careful when tightening the nuts and bolts. Make sure the captive nuts are positioned properly, or you may crack the acrylic. Follow the specific order shown in the instructions when tightening the bolts. So just the one pic here of the jig in place. That concludes stage 10. delboy271155 attached the following image(s): COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Hi, Stage 11 Attach the lead screw nut to the table base.The parts supplied in the first pic.(You will also need the table base) There`s nothing much to this stage. Be sure to align the lead screw nut as shown in the instructions. Fit the washer and nut and tighten carefully. Picture of the end result. Keep the 2mm allen key safe. That concludes stage 11 and pack 3. delboy271155 attached the following image(s): COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Coming together very nicely. Hope the end result provides loads of entertainment as its a very amaxing piece of technology - i want one of these so i will print one. Amazing stuff. Happy Modelling
Great to see another update on this Derek, looks like getting by with out any difficulties, won't be long before you're a technophile
Hi, Tony: I`m hoping to get loads of useful fun out of this when complete. Maybe when I get my head round it even some improved parts for plastic kits. Dave: The build itself is excellently covered in the instructions, the bit that will tell if I`ve made it to a technophile is if I can make it work when it`s finished. Only time will tell. Hope to post next update soon. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
looks like I'll have to revisit my build before proceeding, to reposition the cooling fan! Thanks for the heads up about the amendment. Build looks great!
Couple questions: in Stage 5 the instructions have the 'seal side facing the panel', toward the fan guard. Does the amendment change that? it looks like yours is the other way around is that what the amendment calls for?
AgentReverie wrote:looks like I'll have to revisit my build before proceeding, to reposition the cooling fan! Thanks for the heads up about the amendment. Build looks great!
Couple questions: in Stage 5 the instructions have the 'seal side facing the panel', toward the fan guard. Does the amendment change that? it looks like yours is the other way around is that what the amendment calls for? Firstly, thanks for looking in. Next, in answer to the the above, it`s official I`m a plonker. Missed that bit, somehow, about the seal so will now have to re-position again. So, in conclusion:
With the fan seal facing the fan guard, the wires should leave the fan at the bottom right and not the top right. Pic below. Thanks AgentReverie, have also amended the amendment. delboy271155 attached the following image(s): COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
I'm just glad it's sorted out and that I wasn't imaging things! I guess an extra pair of eyes helps sometimes. At any rate this way I can make the adjustment on my build right away.
Hi, So it`s on to Pack 4. Stage 12: You will need the parts supplied for this stage and the 2mm allen key supplied in stage 11. Fit the timing pulley 1-2 cms from the end of the slider rod as shown in the picture and lock it gently in place with the set screw. The pulleys position will be adjusted at a later stage. delboy271155 attached the following image(s): COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Hi, Pack 4 Stage 13: You will need: Slider and pulley from stage 12 The parts supplied for this stage and the 2mm allen key. First fit the 8mm set screw into the slider until about only 3mm is showing. Fit the slider onto the rod, with the set screw facing the pulley that has been fitted previously. Next fit the long pulley on the rod with the set screw toward the centre of the rod. Tighten the set screw gently, making sure the pulley is 1-2cms from the end of the rod and the set screws of the two pulleys are in line with each other (as indicated by the red arrows). delboy271155 attached the following image(s): COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Hi, Pack 4 Stage 14, You will need: The parts supplied for this stage Slider rod from stage 13 ID Box housing Fit a long belt on the short pulley, then a long and short belt on the long pulley (with the short belt nearest that end of the rod). Then fit the rod with the belts into the left hand side of the housing. You now have to fit a bearing at each end of the rod. Note: These bearings must be fitted squarely into the housing or you will crack the housing and they must be fitted right up to the shoulder on the outer edge of the bearing. Fit and tighten the 4mm truss head screw into the end of the rod at the rear of the housing and the 12mm one in the front end. Note: Do not tighten the 12mm screw at this time as there is more work to do at a later stage. delboy271155 attached the following image(s): COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Hi, Pack 4 Stage 15 Stage 15 is a copy of Stage 12. You will need: The parts for this stage 2mm allen key Fit the pulley on the rod as before 1-2cms from the end of the rod and fix with a set screw. That`s it for pack 4. Keep any used parts safely for use later. Regards delboy271155 (Derek) delboy271155 attached the following image(s): COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Well it`s been a while. The good news is that this is built and passed the set up tests. I`ve got pics of packs 5-8 and end of pack pics for 9-12. Found it a bit difficult to photo the latter stages due to light reflection, but pics show pack completion. Amazingly for a Techno-fobe it passed the set up tests without incident. Must be easier than I thought. So here`s pack 5: delboy271155 attached the following image(s): COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Guest (6)
