9 Pages «<23456>»
Marks ENTEX 1:8 Mclaren M23 James Hunt Options
RM1
#61 Posted : 24 May 2015 16:20:00
Looking good.BigGrin
mark8454
#62 Posted : 25 May 2015 11:43:57
Helmet painted, will let it cure then clear
mark8454
#63 Posted : 25 May 2015 11:45:21
If you look closely I have drilled out some holes for the rivets
mark8454
#64 Posted : 25 May 2015 14:07:53
So happy with my paint test! Perfect!
Thoughts please :)
37916319
#65 Posted : 26 May 2015 08:13:35
Rank: Beginner Level 1
Paint looks awesome. I'm currently building a 1:12 MP4/6. I've got most bases covered except paint, im nervous about the 2 tone masking.
What paints did u use and what procedure did you follow to apply to body/sample?
Very curios to see result once decals added and cleared.
keep up the great work.
mark8454
#66 Posted : 26 May 2015 09:26:26
Hi was used with halfords gloss white tamiya TS orange paint and halfords clear laquer,
Of course the shop halfords wouldnt be in your part of the world but any automotive spray you could use,
I am now debating if i should use these paints instead of some ofther specific paint I bought for the Malboro red.
and also the masking tape i used was from TAMIYA, i have to say its amazing stuff, I have never had a good line before from using any other tape,
I have thought that although many others may disagree with me I may apply decals OVER ther clear coat not UNDER, everytime I have tried under the decal always bubbles and I dont want to risk a fantastic job to make that tiny bit better :)
RM1
#67 Posted : 27 May 2015 08:24:36
Nice glossy finish Mark BigGrin
You mention a Tamiya TS orange, what TS Number is that ?
Thanks
Malc.
mark8454
#68 Posted : 27 May 2015 10:22:56
TS36 I think but I'll double check, it's a beautiful orange in the sun and a deep red in dull light beautiful!!!
Warthog
#69 Posted : 27 May 2015 10:52:52
That is a pretty amazing finish for someone who was not sure what to do a few weeks ago and needed all that advice! Well done Mark and if you can do that with a rattle can then I would ditch the airbrush and would even go as far as saying that's as good as a car body repair shop can do to!
Spencer
mark8454
#70 Posted : 27 May 2015 11:53:50
Thanks very much for the compliment mate, means a lot, I will keep a very comprehensive build diary to keep you all up to date!
Here's the cockpit masked for black inside then may get the white done today :)
mark8454
#71 Posted : 27 May 2015 11:54:41
mark8454
#72 Posted : 27 May 2015 11:58:29
Also Spence, my ex wife once told me when my son was born, sometimes you just have to do what you think is right and stop asking for advice on things that deep down you know the answer to, I think deep down I knew how to do it but but was constantly looking for reassurance.
Once again thanks for the compliments it means a lot coming from a pro modeller BigGrin
Warthog
#73 Posted : 27 May 2015 12:47:34
Your right Mark you do just have to jump in and get on with it and thank you for the compliment in return!
Be very careful when it comes to painting the panels etc as there is a lot of work that needs to be done prior otherwise your going to find that when it comes to attaching the parts together your going to have to remove paint from certain areas.
Spencer
mark8454
#74 Posted : 27 May 2015 13:57:40
Good point Spence,
Most parts will be okay but the rear wing will be a nightmare Glare
mark8454
#75 Posted : 27 May 2015 15:28:32
Update galore!
mark8454
#76 Posted : 27 May 2015 18:37:06
Right last one for today...
Cockpit painted white for the tamiya red
Warthog
#77 Posted : 27 May 2015 22:19:33
Looking good Mark Love just a quick question regarding the gloss white on the top canopy. I know your going to be putting Tamiya fluorescent red next but why gloss and not a white undercoat then the red and then a clear coat? I'm sure there is method to your madness so to speak BigGrin
Spencer
mark8454
#78 Posted : 27 May 2015 23:02:25
Never thought of that, will that affect the finish in a bad way do you reckon?
Warthog
#79 Posted : 27 May 2015 23:54:17
I thought you had already tried it in your earlier posts with the car body test sample?
Spence
mark8454
#80 Posted : 28 May 2015 07:09:20
Either way, the results are incredible!!
9 Pages «<23456>»
This page was generated in 0.260 seconds.
