Lexan body fitting problem Options
stevecol
#1 Posted : 25 May 2015 17:51:02
Rank: Beginner Level 1
im having a spot of bother with fitting the lexan body. I followed the instructions very carefully but cant understand how the side barge boards interact with the two notches under each side pod of the lexan body. If someone can post a close up photo of how it should look that would be great.
kenjara
#2 Posted : 26 May 2015 14:23:12
This is the only photo I can find for the moment, so not sure if will help you or not.
The body should just sit over the outer edge of the board.
Full size image.
This page was generated in 0.119 seconds.
