 Rank: Pro  Groups: Registered
Joined: 25/04/2015 Posts: 154 Points: 462 Location: Northern California, USA
Garth and Daisey, Thanks for the kind words. I'm really enjoying it as well. More photos to come very soon. Dominick
On the Bench: DeAgostini HMS Victory, Moebius Creature From The Black Lagoon Up Next: We'll See
Folks, I'm looking to buy some bail buckets for the launch and (later) some general buckets and fire/sand buckets for the ship deck. Does anyone know what size buckets are appropriate for 1/84 scale. I see 6mm, 9mm, 10mm, etc. but I'm not sure which are an appropriate size for the scale. Any suggestions? Dominick
Id say about 3mm for the buckets, I once made some powder buckets from rolled copper tape. The brass ones at the top of this page would be about right - http://www.cornwallmodel...aA4143_2f03#aA4143_2f03
Steve, Thanks. They look to be very reasonably priced as well. I'll figure out a few more bits and bobs to get and then place a larger order so that shipping isn't 5x the price of the goods. Dominick
Finished, the launch is finished and I am very pleased with how it turned out. I got quite a sense of satisfaction out of completing that. Here it is empty, and with all of the accessories stowed. DSoldano attached the following image(s): Dominick
And here's all of the ship and deck fittings carefully packed in tissue paper or little plastic containers and then neatly stored in a nice sturdy shoe box until they are installed on HMS Victory. Tomorrow I'll clean off the workbench in anticipation of Part 2: Packs 11 - 20 which should be arriving soon. DSoldano attached the following image(s): Dominick
Nothing wrong in keeping them safe, Dominick, well done. Rgds, Hans "It's okay to make mistakes. mistakes are our teachers - they help us to to learn, even if it is painfully" Current Build: Endeavour Cross section,D51 Completed: HMS Victory Under the bench: Endeavour x 2,Sovereign of the Seas, Akagi and The Black Pearl!HMS Victory Cross Section
Gi Diminic. The launch looks superp. keeep up the good work Ian. Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
Hans, Thanks. I figure it could be a year or more before I need them again so best to keep them safe and dust free. Ian, Thanks. I am very pleased with it - I never would have thought I could have done so well with my first planking job. I avoided it for many years because I was afraid of screwing up. To anyone else that's holding off on doing something like this because they are worried about planking I would say, take the plunge - you won't know until you try. Dominick
Guess what came in the mail yesterday? Here goes... DSoldano attached the following image(s): Dominick
I've started putting together the rest of the frames for the aft section of the hull. I should have them finished by the end of the weekend and then I want to give a few of them a light soak and try to straighten out some of the warps. None of them are too bad and I can probably jockey them straight as part of the hull and false deck assembly but I want to try straightening them one more time before assembly. In the mean time, I've also picked up the Owner's Manual for the real HMS Victory published by the Royal Navy. It seems a pretty good book so far, a lot of history and photos and very good technical descriptions of many of the ship's construction features and furniture; very informative. DSoldano attached the following image(s): Dominick
 Hi Dominick That is a great book and good for reference, Did you know Jase has a photo pack available for the Victory aswell, link below. http://forum.model-space...sts&t=1091&p=15
Regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Hi Dominick, great to see the second pack safely in your hands... Andy's recommendation of looking at Jase's photo packs is well worth taking a look at, packed full of beautiful pics and detailed information...  .. Look forward to seeing your progress.... Regards Alan
Alan and Andy, Thanks. I'll PM Jase regarding his photo packs. Dominick
All of the frames are now assembled and the rest of the frame components have received a light sanding on the edges to remove the bulk of the charcoal from the laser cutting process. I just finished the last 2 this morning and those are nice and flat. I plan to give those a few more hours to dry under the book stack and then I'll clear off the garage bench (I'm trying to do the bulk of the sanding work outside to keep the inside workshop as dust free as possible) and work on flattening any that are warped. Next up, I'm going to try to convince the wife  to let me borrow the glass coffee table top off of the patio table and use it to straighten the warped frames (wish me luck) so I don't have to go and buy a piece of glass. Then I'll give any of the frames that are off a short soak and press them for a good week or so to get them as straight as possible. While those are drying out I plan to build the second 12 pounder and the barrel stack. Dominick
Andy, Thanks m8. I just looked through, what a wonderful build. The rigging work was incredible. I'll definitely refer to it when I get to the rigging stage. I also think the way he did the gun port linings was ingenious. Dominick
Today I finished the second of the ship's 12 pound cannons and started on the barrels. First I lightly sanded the barrels to clean up any fuzz. Then I aged them using Weather It. I got the idea from member Steve_O's beautifully aged deck (credit where credit is due). I really like the way they came out - they look much more like real barrels now. I am following the suggestion in the instructions about using thin masking tape instead of painting the iron hoops. I started with an 8 inch piece of Tamiya 6 mm tape and cut a few 1mm or so strips. Instead of painting the strips I decided to use a black Sharpie marker which worked really well but... I wanted to make sure the tape never comes loose so I started to apply a little thin CA with a micro brush. Alas, some of the ink started to bleed into the CA (see the first picture). Luckily I caught it in time and was able to recover by making that the bottom of the barrel pair. Shame because I wanted to add some light rusting to the metal bands. Here's what it looks like without the bleed over (picture 2). And how it will look when it is mounted on the skids (picture 3). I still plan to paint the skids and eyelets black and add the line to tie the barrels down. I should finish that in the next few days and by then all of the frames that are being pressed should be dry and hopefully warp free (or at least very close to warp free). DSoldano attached the following image(s): Dominick
 Nicely done Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Neat work as ever Dominick. You may also want to consider popping a couple of cocktail sticks in as bungs. Have a look here- Barrels
Thanks Gents, John, you had me there - I had to look up what a bung was  but it's a great idea. I'll post some pics when the barrels are done with the bungs installed. Dominick
Guest (14)
