Thanks Guys @ Kev, that extra thin cement is absolutely brilliant, and made all the easier to use because of the very fine brush in the cap. I shall be using that a lot more now. thanks again Happy building David
Nice to know it was helpful to you David and thanks for the acknowledgement, very much appreciated!!
Not sure if you've heard of these, but there are things called 'Riffler' files that will help you in filing those very small vents once you have drilled them and before using the Tamiya 'Extra Thin'? You can see them here:
http://www.ebay.co.uk/it...D111311786009&rt=nc
That may not be the best (or cheapest) seller on ebay but the advert shows the tools in good detail?
Hope that helps/
Kev
Can't say I've seen those before Kev, but they look as though they could work well in an awkward spot, and I'm always open to try something new . Think I'll get myself a set of those. Thanks Happy building David
Hi David. Certainley looking like a sub now more planking is going on. The repair job you done looks fantastic dose not notice at all. Look forward to seeing more of your build Ian. Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
Thanks Ian, I wouldn't say that but it is an improvement and when I get my new Micro Mesh, I can give it a better smooth off and it will be ready for the primer. It actually looks better than those pictures show because that 'macro' lens on the camera shows up every imperfection, and as luck would have it, the repair will be on the opposite side to the display side with the 'cutaways' so it won't be visible anyway. Thanks again for the feedback, it is much appreciated Happy building David
BUILD UPDATE #33
Hello friends, This time we're making a start on the framework for the deck. To begin, we'll use the parts I've already received which are: Issue #14, parts #78 & #79 Issue #15, parts #80 & #81 Issue #16, parts #82 & #83 These being the transverse ribs which fit along the hull in the appropriate slots and sit on the previously planked section of the upper hull. They are not glued in place. A little filing out of the slots was needed to get them to sit correctly so that they lift in and out with ease. The parts supplied in issue #33 are the longitudinal vertical frames which run under the deck area to the left and right-hand sides of the main keel. After removing them from the sheet and giving them a light sanding to remove any rough edges, they were glued into the slots on parts #78 throu #83 using a cocktail stick to apply the glue in the slots, and left to dry in situ. Well, that's all for now. Thanks for all the comments and help - much appreciated, and thanks for looking in. Happy building David
daffy09 attached the following image(s):
 Lovely work David coming a long a treat Rgd Martyn Building ? Completed. Soliei Royal . Sovereign of the Seas . Virginia . Scotland . San Felipe . Corel vasa , Santisima Trinadad X section , Vasa Next Build ? When sailors have good wine, They think themselves in heaven for the time. John Baltharpe
 Starting to look the part now David Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
She's looking great Dave, really enjoying your build..... Regards Alan
Lovely job there David, she looks great. Following with interest as I might add this one to my collection. Rgds, Hans "It's okay to make mistakes. mistakes are our teachers - they help us to to learn, even if it is painfully" Current Build: Endeavour Cross section,D51 Completed: HMS Victory Under the bench: Endeavour x 2,Sovereign of the Seas, Akagi and The Black Pearl!HMS Victory Cross Section
Nice job david, that repair job on the vents looks great and as you say due to its position will not really be visible on the finished model. Graeme
Thanks for the nice comments guys, I'm really pleased with how she's coming along now. There are a couple of issues not directly associated with building the model. One is that I really must have a go at tidying up my worktop, the photos in the diary have really emphasized how untidy it is and there are bits and pieces everywhere. The second is that the model has got to a stage where I cannot use my jig any more, but fortunately, fitting the plastic cladding at the stern (the bit with all the ballasting vents drilled out) has strengthened up that part of the keel and has seemingly straightened out the small bend in that area which is one reason why I built the jig in the first place. I am also considering the option of running some LED lighting into the hull before I get too much further into the build, so that the cutaways can be illuminated. My initial thoughts are 2 warm white, and 1 red led (switched separately)in each compartment, controlled from a 9 volt battery and switch outside the model. Another thing I still have outstanding is the purchase of the rest of the parts for the torpedo room conversion. So far, I only have the rear bulkhead, the floor and the side walls, so I still have the torpedo tubes, ceiling assembly, a couple of torpedoes and some P/E hand wheels to get. Only buying 1 part each month is the most I can do, so the planking of the front end might take a while longer to complete than I at first thought. Any thoughts and feedback would as usual be welcome and appreciated. Happy building David
Well done David, certainly moving on apace now and looking good.
Maybe you should build a little 1:48 scale 'Enigma' coding machine to put in the cutaway section?
Found this...:
http://www.monroeperdu.c...NIGMA-Machine_p_58.html
... but unfortunately, it's 1:32 scale!
Kev
That's amazing Kev, pity it's 1/32 scale though. My skills won't stretch to making one of those at 1/48 scale Thanks for looking in and Happy building David
BUILD UPDATE #34
Hello again, This week it's the turn of the longitudinal horizontal framework which forms part of the removable section of the deck. Issue #34 contained a sheet with 4 of these frames and 4 small reinforcing parts. After removing from the sheet and cleaning up any rough edges, they were placed end to end and checked for correct alignment, then test fitted in to the slots on the previously assembled vertical framework. With everything lining up OK, and using a cocktail stick to apply the adhesive to the parts, they were fitted into place and left to dry. Next, the small reinforcing parts were test fitted in their appropriate slots, and with all fitting with no additional sanding, they were glued into place, again using a cocktail stick to get into the small slots. So that's 2/3 of the deck framework completed, last last 1/3 to be fitted in the next update. Thanks for looking in and for all the positive comments. Happy building Daviddaffy09 attached the following image(s):
 Looking great Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Hi David. Shes certainly taking shape now. look forward to seeing your next instalment. Ian Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
BUILD UPDATE #35
Hi guys, This time, the removable deck framework is finished off and painted. Issue #35 came with 1 sheet containing the last 2 horizontal longitudinal beams and 16 small reinforcing parts to finish the last 1/3 of the framework. As with the last update, after the parts were removed from the sheet and cleaned up, the large horizontal beams were dry fitted and with no adjustment necessary, they were glued into position using a cocktail stick to apply the adhesive to the slots. Some glue was also added to each end to marry up securely with the previous beam and the end of the framework. After leaving in situ to dry, the 16 small reinforcing parts were added after carefully noting their relevant positions as each part was a slightly different shape to allow for the contours of the plastic hull cladding which will be fitted at a later stage. Again, I used a cocktail stick to apply the adhesive to the parts. After the work was completely dry, the section was removed from the main part of the build and given a coat of Humbrol #33 acrylic matt black. Unfortunately, my airbrush decided to stop working on me half way through, so I had to finish the work off with a good old fashioned paint brush. Like Graeme (aka Pemberg), I am considering running in some FOC's to light up the interior of the cutaway sections, but this job will have to done before I get into cladding the build with the wooden strips which we'll receive over the next 7 or 8 weeks. That's it for this one. Thanks for the positive comments and for looking in. See you next time. Happy building David
Looking great David, sorry to hear about your airbrush, hope its nothing too serious. Graeme
Hi David. Just caught up with your build diary. shes looking superp. look forward to seeing more ian Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
Guest (11)
