13 Pages «<678910>»
Dominick's Build Log Options
#141 Posted : 07 June 2015 01:20:37
DSoldano
#142 Posted : 07 June 2015 01:42:11
Alan, Steve,
Thanks. I raised the keel slightly off of the building board and turned her upside down. It would really be terrible to have it glued to the building board. It should be dry by tomorrow and I plan to install the wood beams on the inside of the frames tomorrow.
Andy,
Thanks for the link. That is probably the most incredible build I have ever seen either on the web or in a museum. If I do the cutout I might try some of what he did but I doubt that my skills are up to all of it.
Dominick
On the Bench: DeAgostini HMS Victory, Moebius Creature From The Black Lagoon
Up Next: We'll See
DSoldano
#143 Posted : 07 June 2015 01:44:28
Gents,
Quick question, if I do the cutout, do I need to worry about the nail heads on this deck?
Dominick
Up Next: We'll See
#144 Posted : 07 June 2015 02:13:53
BigGrin Hi Dominick
I showed you Bernds build to give you an idea of what is possible with the build of course I do not expect you to reproduce the same I am just showing what is achievable. As for the basic cut out it is planked over the ply deck in this area but I would probably plank the deck further back by at least a hull template further to each side than recommended then before adding the upper deck paint the inner sides of the planking black below the next deck. hope this helps
#145 Posted : 08 June 2015 14:41:55
Hi Dominck.
Looking good. you will soon be on to the hull planking.
Look forward to seeing your progress IanCool BigGrin
DSoldano
#146 Posted : 09 June 2015 00:22:49
Ian,
Thank you.
I installed the main gun deck beams (the ones on the sides that the false cannons mount to) and the cross beams for the second gun deck. All went together fairly well. As you can see from the state of the model I opted to go with the cut out.
I also applied two coats of black to the areas that will be inside the cannon ports.
Here she is at this stage.
My only concern is that a number of the arms from the frames are still a bit warped above the deck line. I'm hoping these will straighten out with installation of the next few decks. Any advice mates?
I also soaked and weighted the next deck sections as they were a bit cupped.
DSoldano attached the following image(s):
Dominick
Up Next: We'll See
DSoldano
#147 Posted : 11 June 2015 02:23:22
While waiting for the decks to flatten out I completed the stern assembly.
Dominick
Up Next: We'll See
DSoldano
#148 Posted : 11 June 2015 02:24:28
And the bow
Dominick
Up Next: We'll See
#149 Posted : 11 June 2015 07:27:26
Looking good, keep the pics coming Cool
#150 Posted : 11 June 2015 07:27:45
Coming along very nicely Dominick, very well done.... Cool Cool
#151 Posted : 13 June 2015 00:08:17
BigGrin Looking great and a nice startCool
#152 Posted : 13 June 2015 00:14:24
DSoldano
#153 Posted : 15 June 2015 01:38:34
Jase, Alan, Andy, and Steve,
Thanks mates.
The second gun decks finally dried out much flatter after soaking and weighting. Then I test fit and adjusted the decks as needed. shaped and bent the support beams and drew the deck boards and tree nails onto the rear portions of the second gun deck. I used Steve's method of weathering the deck with a 50/50 mix of Weather-it and water. It looks great. Thanks for sharing Steve.
Next I glued the decks to the thwarts and used the deck beams and coffee mugs filled with water to weight the decks. The I'll seal the drawn on planks with some Tung Oil.
I still want to adjust/straighten some of the frame arms. I plan to glue the deck beams to the deck without gluing them to the frames. Once that's dry I'll adjust any of the frame arms that need straightening and clamp and glue them to the beams to get them in position for fairing and planking.
Here's the weathered deck.it has a plywoodylook here but It dried much more even.
I'll post more pictures tomorrow.
Dominick
Up Next: We'll See
Gauncer
#154 Posted : 15 June 2015 04:08:29
Looking good. Love that you are doing the weather-it..
In the workshop: HMS Victory
Finished builds: Providence Whaleboat
#155 Posted : 15 June 2015 08:01:57
BigGrin Lovely work Dominick the decks look spot on ThumpUp
#156 Posted : 15 June 2015 08:41:54
BigGrin Looks greatCool
DSoldano
#157 Posted : 16 June 2015 05:45:24
Thanks Gents,
I started straightening all of the arms of the frames. I used rubber bands (as shown in the photo) to pull the offending arms into line and then glued them to the deck support beams. I actually took the batch of rubber bands that you see in the photo off this evening and it worked great. I have a few more to straighten on the starboard side and then a very few to get on the port side.
Then I'll paint the required areas black, apply some Tung Oil to the simulated planking to seal it, and then it's on to fairing.
Laugh Laugh Laugh
Dominick
Up Next: We'll See
#158 Posted : 16 June 2015 12:29:41
Hi Dominick.
Realy starting to take shape now. look forward to seeing more of your build. IanCool BigGrin
DSoldano
#159 Posted : 16 June 2015 16:11:14
Thanks Ian,
I am getting close to starting the fairing (probably this weekend outside the front of the garage to keep the dust down) and I had a few quick questions for the group. Confused
1. At the bow, should the false keel and doublers be rounded or left flat to accept the keel and planks? Or is the false keel itself left flat and the doublers sanded roundish?
2. At the stern, it appears that the plywood bulkheads get sanded all the way down to the false keel so that the stern follows the angle of the false keel, is this correct?
3. I assume I sand any decks that protrude past the frames even with the frames but that I do not sand any frames even with the deck. Basically, if the frame protrudes past the deck but is fair with the other frames that is the correct profile? Or do I sand all of the frames fair to match the false decks?
Thanks M8s - your advice is always appreciated.
Dominick
Up Next: We'll See
DSoldano
#160 Posted : 20 June 2015 02:45:56
Looks like DeAg billed for month 3 so I should see issues 21-30 in a week or so.
The hull assembly is complete and all the parts that need to be painted black are done.
Fairing starts tomorrow morning, wish me luck.
Dominick
Up Next: We'll See
Guest (19)
13 Pages «<678910>»
This page was generated in 0.328 seconds.
