ModelSpace UK & USA Customer Services Options
#1 Posted : 08 June 2015 14:15:21
ModelSpace UK & Ireland dedicated number:
0333 300 1516 or 0333 240 1227 (Mon-Fri 8am - 5pm)
Some Modelspace subscriptions remain under one c/s number and others on the other c/s number. Generally, if your Subscriber number has Letters before it, you need to use the 1516 number.
Note - Calls to 0333 numbers are charged at the same rate as dialling a local or national number.
Also, if your fixed line or mobile service has inclusive minutes to local or national (01/02) numbers, then calls to 0333 are counted as part of this inclusive call volume.
R2-D2 droid:: 0333 300 1049
Jaguar E-Type: 0330 041 2290
ModelSpace USA: (877) 544-6779
This page was generated in 0.024 seconds.
