 Rank: Semi-Pro Level 1   Groups: Registered
Joined: 17/05/2015 Posts: 61 Points: 189 Location: PIckerington, Ohio USA
This is a TARDIS I built, it is a scratch build made of Balsa wood. I am awful about scale but one inch on my measuring and drawing = to one foot. File Attachment(s): DwCr13 attached the following image(s):
Adam
Joined: 14/04/2015 Posts: 238 Points: 716 Location: Newcastle
Very nice but you need a scratch build K9 to go with it
I have really thought about it, i need to start working on some drawing and make up a set of plans!!!
Adam
Joined: 01/05/2015 Posts: 43 Points: 132 Location: Clearwater, Florida USA
That's awesome! Did you follow an existing set of blueprints/plans or build it by eye. Either was, it's fantastic.
CRphoto wrote:That's awesome! Did you follow an existing set of blueprints/plans or build it by eye. Either was, it's fantastic.
I built it from eye, I figured/guessed the height of the actors playing the Doctor and then worked my way out from the door to the walls to the floor and roof, then added trim and other details from pics of the different Tardis's used in the history of the show, this Tardis is based off of the new Doctor Who episodes from David Tennant's and Matt Smith's run.
Adam
