gun ports Options
johny5
#1 Posted : 13 September 2010 09:13:23
BigGrin hi all im just starting to cut the gun ports do i need to drill right all the way to the back of the gun suports
Jack Sparrow
#2 Posted : 13 September 2010 09:45:15
Just the hull planking. BigGrin
Trotsky
#3 Posted : 13 September 2010 13:27:59
Can I just recheck this with Mr.T ...I thought it also acted as a central position for the placing of false canon in the deck support so needed to also drill deck support.You may well be right Jack it is not the first time I have missunderstood .
H.M.S Victory
H.M.S Victory X Section
D-51
Trotsky
#4 Posted : 13 September 2010 13:32:21
Sorry not deck support ...gun barrel support beam
H.M.S Victory
D-51
#5 Posted : 13 September 2010 13:51:28
Correct Trotsky, you need to drill into the gun support beams which acts as support for the dummy gun barrels, though there is nothing to drill into at the two bow gun ports either side, which will have closed doors.
Jack Sparrow
#6 Posted : 13 September 2010 16:13:13
I stand corrected sir, and apologize for the incorrect information!!!Crying After checking again I see you need too. Sorry Tomick for jumping the gun!!!BigGrin
This page was generated in 0.098 seconds.
