13 Pages «<7891011>»
Dominick's Build Log Options
#161 Posted : 20 June 2015 09:09:20
BigGrin Hi Dominick
Looks like your last but one post was overlooked so here goes my pennyworth
At the bow any doublers should be faired in profile with the other formers in this area use a plank to check that it follows the curve here and that it makes maximum contact with each hull former. When a doubler is at the bottom of the false keel this should be shaped to match the profile of the hull, do not sand the false keel round.
At the stern you are correct the formers and doublers are sanded down to the false keel. the only part of the false keel that is sanded is the very stern part which needs to be taken down to the specified thickness in the instructions and reference the official build here also. Also check that part 33 is fully seated in its slot as its easy to not do this and it will save a lot of hastle later in the build if it needs to be rectified. About 60% of former 34 will be sanded away to get the correct profile here.
Any decks that are proud of the frames should be sanded back to the frames if the decks are inside the frames by a couple of mm then thats fine.
Link to official build, go to post #7
http://forum.model-space....aspx?g=posts&t=814
Hope this helps
AndyBigGrin
#162 Posted : 20 June 2015 10:43:04
Apologies Dominick, I obviously missed your post but I see Andy has answered all your points fully. If you see you haven't had a response to any particular queries you may have then by all means drop me a PM, that way I'm sure not to miss it and will get straight back to you... Keep up the great work, she is coming along a treat... Cool Cool
DSoldano
#163 Posted : 21 June 2015 01:24:59
Andy and Alan,
Thanks for the replies and advice.
It was a busy day of sanding today. Thank God for my Black & Decker palm sander; it made quick work of the transom which was the biggest sanding job.
Here are some pictures and a few questions.
At the bow (see the two bow shots) the planks have a really nice curve and appear the right shape but stand slightly off of the forward former. Should I build up this former or have I got the shape a bit wrong and should I sand down bow formers 11A more? Right now the curve is very round.
At the stern, the transom is nice and even with the stem of the keel. Should the edges of the transom be completely rounded or is the little bit of step on the edges acceptable?
A few of the arms of the frames seem to have a little more spread than others and I'll need to sand them down. I imagine that later I will have to slightly build up the frames inside the bulwarks.
A very few of the frames were a bit shy and I built them up slightly and will sand them back down. These same ones look klike they will need to be taken down slightly inside the bulwarks.
As usual gents your advice is always appreciated.
Oh, and I'm not sure if you celebrate Father's Day in the U.K. (we celebrate it in the states tomorrow) but if you do, then a Happy Father's Day to all.
DSoldano attached the following image(s):
Dominick
On the Bench: DeAgostini HMS Victory, Moebius Creature From The Black Lagoon
Up Next: We'll See
#164 Posted : 21 June 2015 01:31:53
Hi Dominick,
Unfortunately I am no expert with these plank on frame ships, infact I am only just starting my first ever one. After looking at your pictures though to me it looks like those two formers in picture 2 over been faired a little to much, the way I understand it is that the planks should be sitting flush to the whole former.
Im sure someone with a bit ore knoweledge than me on this will be along soon.
In the meantime happy Fathers day for tomorrow, yes it is fathers day here in the uk too, actually its now as it is now 0030 here BigGrin
DSoldano
#165 Posted : 21 June 2015 02:07:14
Dave,
Thanks for the quick response and Happy Father's Day to you, father or not.
It actually sits perfectly against the two formers in the second picture. My concern is with the main frame to which those formers attach (shown rather poorly in the first pic I'm afraid). It misses that by about 2-3mm.
Dominick
Up Next: We'll See
#166 Posted : 21 June 2015 02:11:20
DSoldano wrote:
Dave,
I see what you mean now, after looking at it again now I can see the gap you mention. Im sorry to say I am a bit too in-experienced to help with this one Sad .
#167 Posted : 21 June 2015 09:19:23
BigGrin Hi Dominick
Happy Fathers Day to you aswel M8.
You have done a great job on the fairing overall although as you point out a little too much may have been taken off the former at the bow its an easy mistake to make as fairing is an art in itself. I think it should be ok as it is here.
The transom will need to be taken back a bit more if you compare yours as it is now with the pictures on the official build you will see whats needed here.
I would not worry too much about the frame arms right now as they will be pulled into there correct position as the planking and decks are added.
DSoldano
#168 Posted : 23 June 2015 03:05:23
Andy,
Thanks M8.
I sanded the stern a bit more. I think it looks a lot like the pictures in the build log.
What do the more experienced members think? Did I get it right? I plan to plank the underside of the transom this week to complete month 2. Perfect timing since I got an email letting me know that month 3 shipped today. BigGrin
Dominick
Up Next: We'll See
#169 Posted : 23 June 2015 07:31:33
Hi Dominick, looks to me like you have the stern just about spot on now.. Well done, look forward to seeing your progress with the planking.. Cool Cool
#170 Posted : 23 June 2015 08:08:44
BigGrin The hull looks spot on Dominick lovely work Cool
#171 Posted : 23 June 2015 15:13:37
Hi Dominick.
Fairing is probably the trickiest part. job done look forward to seeing some planking from you. keep up the good work IanCool BigGrin
DSoldano
#172 Posted : 23 June 2015 15:25:54
Alan, Martyn, and Ian,
Thanks gents. I will start planking the underside of the gallery this evening and should have month 3 (issues 21 - 30) by Friday. I estimate I will be starting to plank the upper hull by this weekend.
Dominick
Up Next: We'll See
DSoldano
#173 Posted : 27 June 2015 01:55:33
Finished planking the underside of the transom supports. The last plank was pretty narrow but closed it up fairly nice.
And, month 3 arrived yesterday so planking the hull starts tomorrow
BigGrin BigGrin BigGrin
Dominick
Up Next: We'll See
#174 Posted : 27 June 2015 08:59:30
BigGrin Looks good from here and will look even better once its sanded backCool
z8000783
#175 Posted : 27 June 2015 09:18:38
Groups: Unapproved
Neat work as ever Dominick.
You may find this calculator useful as well, when you get to the last 10 planks.
Index and plank calculator
#176 Posted : 27 June 2015 10:20:36
Nice work Dominick, she's coming along very nicely. Cool Cool .. Be great to see some of the planking going on so take your time, enjoy the challenge and keep the pics coming.... Cool Cool ..
DSoldano
#177 Posted : 28 June 2015 01:04:14
Thanks Gents,
As always your encouragement is greatly appreciated.
A few posts with photos to follow. Sorry, it will be one post per photo as I'm working off of the iPad and I can't get it to correctly upload multiple photos to a single post.
Getting ready to plank.
Dominick
Up Next: We'll See
DSoldano
#178 Posted : 28 June 2015 01:07:31
Gallery support planking trimmed. I sanded it back a touch too much near the transom but added a small shim to correct it. The starboard side came out correct - live and learn.
Dominick
Up Next: We'll See
DSoldano
#179 Posted : 28 June 2015 01:11:26
Here's the first of the planks applied. Exciting stuff - well, for me anyway. It was a little tricky to line it up flush with the bottom of the gun deck and then pin it. A third hand would have helped immensely. In retrospect I should have clamped a few scraps to the bottom of the lower gun deck to act as a guide rather than using the "run a finger over it test". All in all it came out fine though.
The clamps and plank scraps are to make sure the planks line up perfectly at their joins so the next course lays in perfectly.
Dominick
Up Next: We'll See
DSoldano
#180 Posted : 28 June 2015 01:15:24
And here she is with the bow plank installed. This picture just shows the one but the first plank is completed on both sides of the ship all the way to the bow.
In looking at the official build log, it looks like Tom's planks leave a little less space at the bow. I'll correct that with future courses. I figure it won't be a problem if I have to fill a little at the front of one plank.
Rows 2 & 3 coming tomorrow.
Dominick
Up Next: We'll See
Guest (10)
This page was generated in 0.293 seconds.
