She's coming along very nicely Dave. I find the work station to be invaluable, everything I need for my SOTS build is stored in it ready for when it's needed. Don't think I would be without it now.... Regards Alan
Gandale wrote:She's coming along very nicely Dave. I find the work station to be invaluable, everything I need for my SOTS build is stored in it ready for when it's needed. Don't think I would be without it now.... Regards Alan Thanks Alan, it does look like a quality bit of kit As I have been working nights I have not been getting much time, what little time I have had I am using to get the workstation finished. Its really taking shape now, just a couple more bits to do and its done. Its feeling really sturdy now Im not sure if I needed to or not but I did add some small nails for extra strenght on the joins, although I am pretty sure it would have been fine after the glue had dried properly. I just wanted to make sure Started filling the draws already     Oh and this flew over the garden yesterday, we get a lot of flyovers during airshow season.
Sally-B from Duxford, just checked and she was at the Weston-S-Mare air festival at the weekend Steve
Hi Dave. Looking realy nice. Look forward to seeing more Ian Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
Thanks Steve, I knew someone would be able to shed some light on the aircraft Thanks for stopping by and your comment Ian
Finished the OcCre work station and started filling it up  A bit more progress made with the Trinny. Deck supports added, middle deck added and Rib 12 added. Thats all the ribs now, had a quick dry fit with all the decks and they all fit just fine  no picture of this. I will continue to finish the middle deck then plank it all in one go.
Today is one of those rare days that I have a day off AND no chores that need doing, well apart from repainting the kitchen window sill so I started off this morning with starting the planking after I had left the remainder of the middle deck drying over night. I had precut about 100 planks for the task, I found this quite an easy task, this was probably as I waited until the whole of the deck was in place and had pre cut the planks. It didnt take me long to get through all those planks so after lunch I shall be starting the tedious task of cutting lots more. I will be doing the trenails with a pencil as per the instructions after the deck is complete and had a light sanding.
Hi looks a great kit dave, and your off to great start, looking superb.thinking on this one as next ship when got me victory done.cheers mick. Builds hms victory, suzuki gsx 1300 R hayabusa, honda C B 750, lamborghini countach L P 500 S, tamiya 1/16 rc full option tiger 1 tank, built, Mclaren M P 4 - 23. Occre london tram, Stash.airfix 1/24 mosquito. Diag Virginia schooner, tamiya 1/6 honda 750, tamiya 1/35 famo, tamiya 1/35 flak 88.
 Lovely work on the planking Dave looking good Rgd Martyn Building ? Completed. Soliei Royal . Sovereign of the Seas . Virginia . Scotland . San Felipe . Corel vasa , Santisima Trinadad X section , Vasa Next Build ? When sailors have good wine, They think themselves in heaven for the time. John Baltharpe
Thanks for your comments Mick and Martyn Mick, This is my first wooden ship so cant compare it to the Victory, this however is a fantastic kit and it does seem to be going together really well. I am really looking forward to getting some of the hardwood on that is supplied as the wood looks really nice
Here we have the finished planking of the middle deck, trenailed and 1st coat of Danish Oil being applied, I will apply another 3 layers.
Coming along well Dave, the deck looks good Steve
 Deck looks great Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Thanks Steve and Andy Although I need to get the hang of not applying so much glue as I seem to be wasting a lot when I stick things down and it oozes out the sides resulting in lots of clean up. If you look at that bottle of glue in the work station that was full and only been used for the Trinny and work station
 With glue its all down to practice you will soon get the knack of knowing exactly how much to use to do the job in hand Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Better to use to much and clean up rather than not enough in the first place I guess  I'm sure I will get there the balance right soon. In the meantime while I am adding the coats of danish oil to the middle deck I thought I would see what else I could do. After looking ahead in the instructions I decided I would be safe doing the gratings  so here is where I am; it was fiddly work doing these, I found it easier to tape two of the corners down. Once all the parts were in place I took my CA applicator tool and rubbed it around the inside of each square to fix it all in place. Next was to cut out the grates needed, 5 in total. I have complete one so far, rounding off the edges slightly. In the instructions it mentions to apply varnish, my question is what varnish would people recommend, I think I want a matt finish. Also would you recommend varnishing the danish oil sealed decks or is the oil enough on its own.
You're doing a great job Dave, looking fab.... Regards Alan
 Spot on with those gratings Dave. A quick drying interior varnish will do the trick Rgd Martyn Building ? Completed. Soliei Royal . Sovereign of the Seas . Virginia . Scotland . San Felipe . Corel vasa , Santisima Trinadad X section , Vasa Next Build ? When sailors have good wine, They think themselves in heaven for the time. John Baltharpe
Thanks Alan & Martyn
I will be popoing out to get sone varnish today and to choose what wood stain I want to use
Guest (8)
