Cutting gun ports Options
Peter G
#1 Posted : 24 June 2015 04:12:18
To John Passmore.
HI John, I could not get a connection to your post #145 thru the Forum search facility, so could you describe your procedure in just a few words?? Regards, Peter G
John Passmore
#2 Posted : 24 June 2015 06:22:06
Publisher Medal: Featured Build of the MonthOutstanding Build: An award for an outstanding buildBuild-Diary Medal: Build-Diary Medal of HonourRed Medal: Red Medal
Peter G wrote:
To John Passmore.
Hi Peter
Where you have drawn the square for the gunport, drill a vertical row of small holes (0.4 - 05mm) just inside of each vertical of the square. Drill them as close together as possible, then you can cut through each hole quite easily with a craft knife, starting at the top and drawing the knife down...Cool
Following that you just cut the horizontal top and bottom, then it's just a matter of file/sand back to the drawn lines...BigGrin BigGrin
Trust this clarifies...Cool
Kind regards
JohnP
#3 Posted : 24 June 2015 07:29:12
Hi Peter, this link to John's post on cutting gun ports may help...
http://forum.model-space...sts&t=11368&p=8
Peter G
#4 Posted : 25 June 2015 03:12:18
HI John, Alan, all is even clearer now. Thanx again! Peter G
This page was generated in 0.265 seconds.
