Joined: 27/06/2011 Posts: 437 Points: 1,321 Location: milton keynes
most Welcome make sure you post some piccys your progress regards Dan Built - Deagostini MP4/23, deagostini Zero, Deagostini Falcon, Deagostini R2D2, Model Airways 1903 Wright Flyer, Deagostini Senna Mp4/4. Entex Mclaren M23 1/8th scale to complement the Deagostini MP4/23 & Mp4/4, deagostini Ferrari 312T4, Pocher lotus 72D, Pocher porche, Deagostini Lotus 97T on the bench, Model Airways Sopwith Camel, HK Models B-17F flying fortress, Galactica Viper, Stap droid
well i made a start on the floor, filled some of the sink marks that i thought would still be visible, then proceeded to base coat ready for the carbon decals, alls good. I applied the decals and left for a few days just to make sure everything was good and set. i then masked off some of the areas on the floor and gave all the decals a light over spray of transparent smoke! then an extremely thin coat of matt black just to tone down the bluish effect of the smoke so the decals just barely came through. piccys are pre transparent smoke & black. dandare attached the following image(s): Built - Deagostini MP4/23, deagostini Zero, Deagostini Falcon, Deagostini R2D2, Model Airways 1903 Wright Flyer, Deagostini Senna Mp4/4. Entex Mclaren M23 1/8th scale to complement the Deagostini MP4/23 & Mp4/4, deagostini Ferrari 312T4, Pocher lotus 72D, Pocher porche, Deagostini Lotus 97T on the bench, Model Airways Sopwith Camel, HK Models B-17F flying fortress, Galactica Viper, Stap droid
one slight problem!!!! as i peeled back the masking tape a couple of sections of the decal decided to come with it ????? so that pretty much ruined all my work so long story cut short, sink hot water soft scouring brush, re mask, matt black and im happy! dandare attached the following image(s): Built - Deagostini MP4/23, deagostini Zero, Deagostini Falcon, Deagostini R2D2, Model Airways 1903 Wright Flyer, Deagostini Senna Mp4/4. Entex Mclaren M23 1/8th scale to complement the Deagostini MP4/23 & Mp4/4, deagostini Ferrari 312T4, Pocher lotus 72D, Pocher porche, Deagostini Lotus 97T on the bench, Model Airways Sopwith Camel, HK Models B-17F flying fortress, Galactica Viper, Stap droid
just need to scuff the floor a little more! i also added a few extra detail parts to the right side pod having followed my Mp4/4 detail booklet. regards Dan dandare attached the following image(s): Built - Deagostini MP4/23, deagostini Zero, Deagostini Falcon, Deagostini R2D2, Model Airways 1903 Wright Flyer, Deagostini Senna Mp4/4. Entex Mclaren M23 1/8th scale to complement the Deagostini MP4/23 & Mp4/4, deagostini Ferrari 312T4, Pocher lotus 72D, Pocher porche, Deagostini Lotus 97T on the bench, Model Airways Sopwith Camel, HK Models B-17F flying fortress, Galactica Viper, Stap droid
and then proceeded to make a start on the brake hoses only just started these but thought it would be worth sharing regards Dan dandare attached the following image(s): Built - Deagostini MP4/23, deagostini Zero, Deagostini Falcon, Deagostini R2D2, Model Airways 1903 Wright Flyer, Deagostini Senna Mp4/4. Entex Mclaren M23 1/8th scale to complement the Deagostini MP4/23 & Mp4/4, deagostini Ferrari 312T4, Pocher lotus 72D, Pocher porche, Deagostini Lotus 97T on the bench, Model Airways Sopwith Camel, HK Models B-17F flying fortress, Galactica Viper, Stap droid
 Rank: Master     Groups: Registered
Joined: 26/04/2014 Posts: 1,488 Points: 4,376 Location: Essex
the detail on that right side pod is absolutely outstanding, well done. Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Dodge charger build complete https://forum.deagostini....1686229545.1.1.utmcsr=(direct)|utmccn=(direct)|utmcmd=(none)&__utmv=-&__utmk=9709046
Thank you Steve  very kind comments unfortunately the old camera is not the greatest i think ive managed to find a setting that allows close ups, so here are a few more!!! although any little speck of dust is now really highlighted!! will have to get the old Vacuum on it before the next set of photo's Regards Dan dandare attached the following image(s): Built - Deagostini MP4/23, deagostini Zero, Deagostini Falcon, Deagostini R2D2, Model Airways 1903 Wright Flyer, Deagostini Senna Mp4/4. Entex Mclaren M23 1/8th scale to complement the Deagostini MP4/23 & Mp4/4, deagostini Ferrari 312T4, Pocher lotus 72D, Pocher porche, Deagostini Lotus 97T on the bench, Model Airways Sopwith Camel, HK Models B-17F flying fortress, Galactica Viper, Stap droid
 Looks great Dan Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Joined: 02/03/2015 Posts: 84 Points: 245 Location: England
Looks great! The CF has come out nice. Which colour did you use underneath the CF? Building the MP4/4!
Looking good Dan. The setting you found sounds like macro mode, as you have found the only problem is it does show up every tiny speck of dust
arpurchase wrote: Looks great Dan Hi Andy, thanks for looking in regards Dan Built - Deagostini MP4/23, deagostini Zero, Deagostini Falcon, Deagostini R2D2, Model Airways 1903 Wright Flyer, Deagostini Senna Mp4/4. Entex Mclaren M23 1/8th scale to complement the Deagostini MP4/23 & Mp4/4, deagostini Ferrari 312T4, Pocher lotus 72D, Pocher porche, Deagostini Lotus 97T on the bench, Model Airways Sopwith Camel, HK Models B-17F flying fortress, Galactica Viper, Stap droid
Phil wrote:Looks great! The CF has come out nice. Which colour did you use underneath the CF? Hi Phil thanks for looking in, i had originally used a mix of aluminium & gun metal, however once the decals decided to peel off i reverted back to good old Matt black and No decals. regards Dan Built - Deagostini MP4/23, deagostini Zero, Deagostini Falcon, Deagostini R2D2, Model Airways 1903 Wright Flyer, Deagostini Senna Mp4/4. Entex Mclaren M23 1/8th scale to complement the Deagostini MP4/23 & Mp4/4, deagostini Ferrari 312T4, Pocher lotus 72D, Pocher porche, Deagostini Lotus 97T on the bench, Model Airways Sopwith Camel, HK Models B-17F flying fortress, Galactica Viper, Stap droid
davetwin wrote:Looking good Dan. The setting you found sounds like macro mode, as you have found the only problem is it does show up every tiny speck of dust Hi Dave Thanks for looking in, for the life of me i swear there was no dust prior to taking the pic  clearly that macro setting does indeed pick up anything micro Regards Dan Built - Deagostini MP4/23, deagostini Zero, Deagostini Falcon, Deagostini R2D2, Model Airways 1903 Wright Flyer, Deagostini Senna Mp4/4. Entex Mclaren M23 1/8th scale to complement the Deagostini MP4/23 & Mp4/4, deagostini Ferrari 312T4, Pocher lotus 72D, Pocher porche, Deagostini Lotus 97T on the bench, Model Airways Sopwith Camel, HK Models B-17F flying fortress, Galactica Viper, Stap droid
Great Detail! Love your build!
WalterGreetings, Walter
DaDokta wrote:Great Detail! Love your build!
Walter Thank You Walter very kind of you & thank you for looking in Regards Dan Built - Deagostini MP4/23, deagostini Zero, Deagostini Falcon, Deagostini R2D2, Model Airways 1903 Wright Flyer, Deagostini Senna Mp4/4. Entex Mclaren M23 1/8th scale to complement the Deagostini MP4/23 & Mp4/4, deagostini Ferrari 312T4, Pocher lotus 72D, Pocher porche, Deagostini Lotus 97T on the bench, Model Airways Sopwith Camel, HK Models B-17F flying fortress, Galactica Viper, Stap droid
Joined: 01/12/2014 Posts: 102 Points: 312 Location: Chicago, IL
Dan,
Awesome work!! Sorry I'm going to steal more of your creativity!! Did you use shrink tubing on some of those extra hoses/lines?
Jim
NSXKid wrote:Dan,
Jim Hi Jim feel free! thats why we all post here. so others can be inspired  i have used shrink tube on the pipe coming from the top of the intercooler, however ive just ordered and recieved some tubing (1.7mm) from Hiroby to replace it as the shrink tube just does not look good imo. the other tube/pipe is similar to the pipe used in the kit on the brake lines, again this came from Hiroboy. ive also just received a smaller diamater pipe to change the radiator overflow pipes. regards Dan Built - Deagostini MP4/23, deagostini Zero, Deagostini Falcon, Deagostini R2D2, Model Airways 1903 Wright Flyer, Deagostini Senna Mp4/4. Entex Mclaren M23 1/8th scale to complement the Deagostini MP4/23 & Mp4/4, deagostini Ferrari 312T4, Pocher lotus 72D, Pocher porche, Deagostini Lotus 97T on the bench, Model Airways Sopwith Camel, HK Models B-17F flying fortress, Galactica Viper, Stap droid
dandare wrote:NSXKid wrote:Dan,
Jim Hi Jim feel free! thats why we all post here. so others can be inspired  i have used shrink tube on the pipe coming from the top of the intercooler, however ive just ordered and recieved some tubing (1.7mm) from Hiroby to replace it as the shrink tube just does not look good imo. the other tube/pipe is similar to the pipe used in the kit on the brake lines, again this came from Hiroboy. ive also just received a smaller diamater pipe to change the radiator overflow pipes. regards Dan sorry the Electrical plugs used thin guage black wire regards Dan Built - Deagostini MP4/23, deagostini Zero, Deagostini Falcon, Deagostini R2D2, Model Airways 1903 Wright Flyer, Deagostini Senna Mp4/4. Entex Mclaren M23 1/8th scale to complement the Deagostini MP4/23 & Mp4/4, deagostini Ferrari 312T4, Pocher lotus 72D, Pocher porche, Deagostini Lotus 97T on the bench, Model Airways Sopwith Camel, HK Models B-17F flying fortress, Galactica Viper, Stap droid
Joined: 10/02/2014 Posts: 63 Points: 189 Location: uk
love the extra detail on the side pods Dan, looks very nice indeed.
shame about the floor decals as i haven't made my mind up yet on what to put on the floor, i have a load of fine carbon decal here which i was going to try and i understand why you smoked it down.
C
casino wrote:love the extra detail on the side pods Dan, looks very nice indeed.
C Thanks for the comments Casino, having had the decals then having to revert back, im much happier with the matt black finish. regards Dan Built - Deagostini MP4/23, deagostini Zero, Deagostini Falcon, Deagostini R2D2, Model Airways 1903 Wright Flyer, Deagostini Senna Mp4/4. Entex Mclaren M23 1/8th scale to complement the Deagostini MP4/23 & Mp4/4, deagostini Ferrari 312T4, Pocher lotus 72D, Pocher porche, Deagostini Lotus 97T on the bench, Model Airways Sopwith Camel, HK Models B-17F flying fortress, Galactica Viper, Stap droid
