11 Pages «<23456>»
Dave's Santisima Trinidad Build - First Wooden Ship Build Options
#61 Posted : 28 June 2015 21:31:59
A small update on progress and to seek some advice and opinions from others.
First of all I finished another crate with another one now in the vice drying before its shaped.
I also finished the 3 layers of danish oil to the middle deck and applied a layer of varnish. I ended up using the varnish that Trudi (SWMBO) got to varnish the kitchen window sill.
I have now also stanied some bits of wood to try and decide what colour to stain the gun whales when I get to them. This is what I need a second opinion on Cool I am liking the Indian Rosewood and the Teak, but I do not know which one would be more of a realistic wood used in the period Confused
With flash, I also stained some planks to compare the look
Without flash
This is the Varnish that I used, I am really happy with the finish on the deck, however I do not think it is completely Matt, it looks like it still has a sheen, will see how it looks tomorrow after all night to dry. I am umming and arrghing if I want a slight seen on the crates or completely matt.
This is how the decks look after the oil and varnish, very nice I think
#62 Posted : 28 June 2015 21:50:57
Dave,
What a great job you are doing with your build, regarding what stain to use for me I think rosewood, don't forget that it will lighten over a time depending on where you display your build,Just a thought.
Trev.
#63 Posted : 28 June 2015 22:25:04
BigGrin Looks great Dave, as for the stains teak would be appropriate as she was built in Havana Cuba so hardwoods such as teak would have been used in her construction.Cool
#64 Posted : 29 June 2015 00:09:59
Thanks Trev & Andy.
I must admit I was leaning towards teak, I still have a bit of time before I need to stain so could still change my mind BigGrin
nightwisher
#65 Posted : 29 June 2015 02:14:33
Nice work Dave,very neat.I use the same varnish,it does leave a slight sheen but I think it looks quite nice after 3 coats.
Had a dream to understand
A single grain of sand
He gave birth to poetry
But one day will cease to be
#66 Posted : 29 June 2015 08:49:34
Thanks for popping in and the comments nightwisher, I will give it another couple of coats. It does say to lightly sand before the final coat, is this something you do when using it?
nightwisher
#67 Posted : 29 June 2015 09:21:57
Yes mate after the second coat is fully dry (about 6 hours) I give it a light sand with a very fine grade sandpaper, dust off and give it a final coat.
#68 Posted : 29 June 2015 22:35:24
Thanks Nightwisher BigGrin
Well just the one picture today, have finished the fist set of grates and applied the first coat of varnish, also started with the second set of grates.
In other work I have applied the second coat of varnish to the deck tonight too, once dry this will be lightly sanded ready for the last coat.
There will be very few updates to this now until I get anything meaningful done.
My modelling time is soon going to be very limited and will have to grab time when I can as at work we will shortly be delivering a large 1:1 railway diorama build BigGrin. This will be one of the largest projects carried on on the Great Western route in decades, this is all due to kick off over the summer holidays lasting 6 weeks so things will be manic Blink
Anyway enough waffling heres the picture LOL
#69 Posted : 29 June 2015 22:37:25
BigGrin Nicely doneCool
#70 Posted : 29 June 2015 23:30:46
#71 Posted : 30 June 2015 09:28:31
BigGrin Looking good Dave ThumpUp
#72 Posted : 02 July 2015 22:27:26
Thank you Andy , Steve and Martyn BigGrin
After using a fine sand paper and gently sanding down the two coats of varnish a third coat was applied. As this has now dried I continued to add the deck supports for the next deck as well as the deck itself.
I have also finished the first 3 grates, 3 coats of varnish also added to them, as well as made more progress on the rest of the grates, will post pictures of them when they are finished.
This is where I am at now. I will plank the top deck in one go
#73 Posted : 02 July 2015 23:57:38
Hi dave coming along real nice there, well done.keep up the good work will be following with interest. Cheers mick. BigGrin BigGrin
#74 Posted : 03 July 2015 22:10:58
Thanks Mick BigGrin
A little more progress has been made.
All the main deck panels have now been glued in place, weighted down or clamped while the glue dried.
I finished making up the rest of the grates and think they came out quite nice, a lot of time was spent on these BigGrin The top too in the picture are completely finished now with 3 coats of Ronseal toughcoat.
All the others now have the first coat of varnish applied.
The very observant will notice I had finished 3 in a previous post and not 2 as in this post, if you look back you will see that one of the 3 x 9 grates I made as a 3 x 10 OhMyGod So out with the saw to chop off a one row, resulting in a new end piece being cut and shaped, then revarnished and added to the others awaiting the last two coats.
Next I used a long (1m) steel ruler to mark the centre line of the decks to start the planking from and finally the front of the bow planked before starting on the deck, which I am really looking forward to BigGrin
#75 Posted : 03 July 2015 22:20:15
#76 Posted : 04 July 2015 09:54:10
She's certainly coming along Dave, great work and a pleasure to follow....Cool Cool
#77 Posted : 04 July 2015 11:29:11
Thank you Steve and Alan
I an really enjoying building her, I mustadmit I was a bit scared of starting but now she is getting in the way of my 2 Millennium Falcons
#78 Posted : 04 July 2015 15:36:49
Hi dave looking great.coming on real nice.if like me I'd not worry bout it taking over for a while, these such enormous projects you probably find you need break from it from time to time.like me with vic.do smaller projects in between.cheers and happy moddelling mick. BigGrin BigGrin
#79 Posted : 05 July 2015 18:59:51
BigGrin Nicely done DaveCool
#80 Posted : 05 July 2015 19:09:08
BigGrin Looking good Dave cracking job ThumpUp
Guest (16)
11 Pages «<23456>»
This page was generated in 0.186 seconds.
