18 Pages «<89101112>»
der Gohfelder
#181 Posted : 23 June 2015 19:33:44
Hi Andy!
Looking simply wonderful, always a pleasure to see your work!
Regards, Bernd
#182 Posted : 23 June 2015 19:40:51
BigGrin Hi Bernd Thanks as always for your commentsCool
#183 Posted : 25 June 2015 23:16:02
Sheathing continues, I thought that a better explanation of how I added the plank that runs along the top of the copper sheathing was called for as when I did the other side I just showed pic's of it painted and it couldnt really be seen. Firstly mark the waterline with a pencil then I used evergreen 0.5 x 1 mm strip to make the plank, stick this above the waterline mark and following the pencil line across the hull. Once the glue is dry it will need about 3 coats of dull black. Simple to do and gives a line to follow at the water line for the tiles to butt up to. More soon.
Black Shadow
#184 Posted : 28 June 2015 15:35:05
Rank: Beginner Level 3
Hi Andy what a beautiful ship the Jotika Agamemnon is. Like all their kits, Caldercraft (Jotika) are some of the best available. I bought the Bomb vessel Granado kit many years ago which I have never actually completed, it is somewhere in the loft packed away, needing the rigging to be tackled. I don't think I have the skill levels to build such a complicated kits as the Agamemnon or their classic HMS Victory, but I will get round to finishing the Granado one day. Meanwhile, I think I can successfully finish the Hatchette U96 and other models I have yet to build.
Your model is a credit to you, but how do you manage to have so many models on the go at the same time. What's the magic potion that keeps you going?
Built : Robbe 1/40 scale Type XX1 Radio Controled : Scratch built 1/48 scale Ton Class Minesweeper Radio Contolled : Caldercraft (Jotika) Bomb Vessel Grando display model.
Building : Hachette Part Works U96.
To Build : DeAgostini 1/4 Honda CB750 : Tamiya 1/6 Harley Davidson Super Glide : Tamiya 1/12 1967 Lotus 49 F1 Racing Car : Revel 1/24 Shelby Cobra : Revel 1/24 Ferrari 250 SP GTO
#185 Posted : 28 June 2015 22:54:35
Blushing Hi Geoff
Thanks for looking in on my build and your kind words. I can only agree with you on your comments about Caldrcraft kits there just top quality throughout and hopefully the Granado will get finished soon. I have no magic potion I just like to spend my time on a hobby I love and to learn from others on the forum to improve my own builds.
Best Regards
#186 Posted : 28 June 2015 23:03:26
The copper sheathing is more or less complete just the stern post to finish on the hull and the rudder to copper and mount. Once that is done it will be time to add the upper outer hull furniture and finish off the gallery's. More soon.
#187 Posted : 28 June 2015 23:16:11
Wow, that really does look quite spectacular all covered in bronze, amazing work Cool
#188 Posted : 29 June 2015 00:28:16
#189 Posted : 29 June 2015 00:39:37
Top quality work as usual Andy, looks simply amazing....Drool Drool
#190 Posted : 29 June 2015 08:20:27
BigGrin Thanks everyone for looking in and your comments and in real life it looks even better than in the pic'sDrool Drool Cool
#191 Posted : 29 June 2015 09:04:04
Magnificent!!! Love ThumpUp
#192 Posted : 29 June 2015 14:06:23
Hi Andy.
Your coppering looks superp. are you going shinny or leaving it to dull.
Ian Cool Cool BigGrin
DaDokta
#193 Posted : 29 June 2015 14:42:44
Looking good Andy!
But may i ask:
Why is there a change of pattern of the tiles at the bow?
It seems, there is a line, from which on the tiles go in a different direction.
Greetings,
Walter
Greetings,
Walter
Present builds:
Revell B-24D Liberator 1:48
On the shelf:
Completed builds:
#194 Posted : 29 June 2015 16:27:24
Hi Andy now that coppering tiles looks superb.sets her off a treat.wonderful build.look forward to more.cheers mick. BigGrin BigGrin
Black Shadow
#195 Posted : 29 June 2015 16:27:24
Brilliant Andy. It's going to be a first class model when it's finished.
#196 Posted : 29 June 2015 23:21:55
BigGrin Thanks everyone for looking in and your comments.Cool
@ Walter, its the hull shape at the bow that is the problem here, I didnt mind adding goring belts at the stern as these were often used in this area but at the bow they were kept to a minimum as it was thought it affected the ships speed.
At the bow the Agamemnon is shaped for speed unlike the Santisima Trinidad or Victory which both have bulbous round front hulls to maximize deck width and therefore the ability to mount more guns.
The Agamemnon bow is a complex curve that would have meant a goring line at aprox every two rows in parts and this to my eye was complex and didnt look right. The curve also prevented edge to edge placement of the tiles as this just left huge gaps and did not look scale as did overlapping the tiles this again caused a clinkering effect that again did not look right.
After reading everything I could find referencing sheathing copper hulls I found there was no set pattern for adding tiles to a hull in other words each ship yard had there own methods of patterning it was just the way the tiles were nailed on that was set in stone which was that the forward edge had the next tiles edge over it thus preventing water action as the ship sailed getting underneath and pealing them off.
My aim was to have continuous rows of Tiles at the bow with no goring lines to do this meant that a natural dogleg was formed at the bow at about the third hull former back this is the straight line you can see. As i have mentioned before in my research a tile pattern like this has been mentioned for this type of hull and could have been on the ship at some point in her life after her many refits. Hope this answers your question.
#197 Posted : 29 June 2015 23:43:02
Looks great Andy you have done a great job.
Copper tiling is one thing I haven't tried yet. My hulls upto now have been either painted or varnished.
Chris
#198 Posted : 30 June 2015 08:18:59
BigGrin Hi Cris
Thanks for looking in and your comments as for tiling if you enjoy planking tiling is on an even par.
DaDokta
#199 Posted : 30 June 2015 08:46:46
Thanks Andy for your detailed answer!
Again i learned something new - which is what i like about this Forum so much.
Thanks,
Walter
Greetings,
Walter
Present builds:
On the shelf:
Completed builds:
#200 Posted : 30 June 2015 20:59:19
BigGrin Glad to be of service Walter, I also forgot to mention that two sides of the bow are slightly different almost as if two different gangs of tilers worked each side of the shipCool
Guest (11)
This page was generated in 0.787 seconds.
