Front reflector spacers. Options
#1 Posted : 30 June 2015 19:47:08
Has anyone received the front reflector spacers in Pack 13??
Unfortunately I did not, so after a call to C/S I have received another Pack 13.This also did not contain the spacers.
Am I just unlucky or do they come in a later pack ?
#2 Posted : 30 June 2015 20:36:19
not fitting them on my build, was only US spec that had them.BigGrin
Warthog
#3 Posted : 30 June 2015 21:20:27
Hi Al
If you look at the official build you will notice that the spacers have not been included in the parts list, and if you intend to do the U.S. Spec as Nem has stated they are on then you could always make them out of plasticard.
Spencer
bugsec
#4 Posted : 23 August 2015 22:51:09
Hi Al,
Bit behind with my build and just opened Pack 13 and I didn't get the spacers either.
In the accompanying booklet fitting the spacers comes after Stage 42 but Tom's Official Build Diary says they are supplied with Stage 41.
None of the stages in the booklet mention the spacers on the parts list.
Reckons there's no point in contacting CS as it looks like they are not included in the pack.
Graham
#5 Posted : 24 August 2015 13:31:03
Hi I'm on pack 14.and not get spacers either.they are shown in pic of contents on stage 41, and a whole page dedicated to fitting them in pack 13 mag.just removed mine as U.S spec anyway.cheers mick.BigGrin BigGrin
#6 Posted : 24 August 2015 13:37:29
Spacer's are not provided hence why they are not shown in my parts contained photo for 41.
bugsec
#7 Posted : 24 August 2015 13:52:16
Thanks for the update Tomick
Graham
This page was generated in 0.890 seconds.
