Well it's finally here, i started out by checking what was there and to see if anything was missing, after unpacking and laying everything out it seems the only thing missing is magazine no. 9, as far as i can tell its all there up to issue No. 80.    Gibbo attached the following image(s): Building: DelPrado HMS Victory. Building: DeAgostini Sovereign Of The Seas.
As you can see the ribs are coming away from their centres, there just isn't any glue, the only things holding them are the pinned planks, the decks are the same.   Gibbo attached the following image(s): Building: DelPrado HMS Victory. Building: DeAgostini Sovereign Of The Seas.
I took an old knife out of the drawer, heated it up and bent it then cut a groove the width of the ribs and used this as a mini crowbar to prise the planks off and keep as many intact as possible. Gibbo attached the following image(s): Building: DelPrado HMS Victory. Building: DeAgostini Sovereign Of The Seas.
after taking the planks off most of the boat just came apart without any problems, no soaking in hot water or steaming ( so far ), to get it to this stage took around an hour and a half, thank god for the lack of glue, this could have been a right pain.  Gibbo attached the following image(s): Building: DelPrado HMS Victory. Building: DeAgostini Sovereign Of The Seas.
 Rank: Pro  Groups: Registered
Joined: 25/04/2015 Posts: 154 Points: 462 Location: Northern California, USA
Paul, I would consider that a stroke of luck. Look how easily she came apart for your restart. Now it's my turn to toast you with a nice McCallan's. Dominick
On the Bench: DeAgostini HMS Victory, Moebius Creature From The Black Lagoon Up Next: We'll See
 Wow that's a bit of luck that they didn't use a load of glue Looking forward to seeing the rebuild Rgd Martyn Building ? Completed. Soliei Royal . Sovereign of the Seas . Virginia . Scotland . San Felipe . Corel vasa , Santisima Trinadad X section , Vasa Next Build ? When sailors have good wine, They think themselves in heaven for the time. John Baltharpe
Definitely a good bit of luck there, making it so much easier for you to start from scratch doing it right
Hi Paul. i can lend you issue no 9. pm me your adreess and i will post it to you and you cansend it back when finished with. Ian Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
Joined: 09/12/2013 Posts: 577 Points: 1,748 Location: smethwick england
Gibbo I cannot believe you have destroyed such a beautiful example of how not to build a ship Man he took his time in the sun Had a dream to understand A single grain of sand He gave birth to poetry But one day will cease to be Greet the last light of the library...We were here!
Looks good  , you almost have a fresh start there - the 2x5mm lime strips are not expensive either should you need to get more. Steve
 Wow looks like a puzzle ship  gone wrong but a perfect way to get a good start on her Paul Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Hi not any instructions me seen on my victory going on there eh.but glad it made it easy to get a restart.cheers mick. Builds hms victory, suzuki gsx 1300 R hayabusa, honda C B 750, lamborghini countach L P 500 S, tamiya 1/16 rc full option tiger 1 tank, built, Mclaren M P 4 - 23. Occre london tram, Stash.airfix 1/24 mosquito. Diag Virginia schooner, tamiya 1/6 honda 750, tamiya 1/35 famo, tamiya 1/35 flak 88.
DSoldano wrote:Paul,
Cheers Dominick Building: DelPrado HMS Victory. Building: DeAgostini Sovereign Of The Seas.
stevie_o wrote:Looks good  , you almost have a fresh start there - the 2x5mm lime strips are not expensive either should you need to get more. Steve Hi Steve Not sure yet whether i'm going to attempt a stained wood finish or a paint job yet, i've managed to salvage about 95% of the planks which i will use if i go for a paint finish, if not i will have to order some more for the stain finish so i can have a go at treenailing, just had a look at Tomick's build and realised there is no veneer layer, on all the builds i've looked at i've never noticed that before, do you know of anybody that has done that on here ? Building: DelPrado HMS Victory. Building: DeAgostini Sovereign Of The Seas.
mogwai wrote:Hi not any instructions me seen on my victory going on there eh.but glad it made it easy to get a restart.cheers mick. It got even easier Mick, i thought the centre part of the ribs were glued onto the keel so i got one of those steamers that you clean your house with to soften the glue, and even they were not glued they were just wedged in there really tight and not all the way in, i realised this after doing a couple because they were getting tighter with the steam, i couldn't have got luckier with this Building: DelPrado HMS Victory. Building: DeAgostini Sovereign Of The Seas.
arpurchase wrote: Wow looks like a puzzle ship  gone wrong but a perfect way to get a good start on her Paul Yeah, happy days, the rest of it just popped out as well. Cheers Paul Building: DelPrado HMS Victory. Building: DeAgostini Sovereign Of The Seas.
nightwisher wrote:Gibbo I cannot believe you have destroyed such a beautiful example of how not to build a ship should have left it and built a rat version of the Vic. Building: DelPrado HMS Victory. Building: DeAgostini Sovereign Of The Seas.
Unbelievable how ugly a hull can be built! Greetings, Walter
DaDokta wrote:Unbelievable how ugly a hull can be built! i think it is quite obvious that he wasn't involved any sort of modelling forum or group, maybe didn't have any history with wood and a lack of tools, the planks weren't pre-bent and the hull not faired, still i'm not complaining it made my life a lot easier. Building: DelPrado HMS Victory. Building: DeAgostini Sovereign Of The Seas.
Guest (12)
