Just joined Options
max001
#1 Posted : 03 July 2015 05:04:46
BigGrin just joined saying hello at stage 15 on spitfire model
c u later
Max001
#2 Posted : 03 July 2015 10:32:27
Welcome to ModelSpace, hope you enjoy your stay with us and your build Cool
#3 Posted : 03 July 2015 10:37:45
Welcome Max, are going to be posting a build log, its nice to see people's build Cool
#4 Posted : 03 July 2015 11:19:49
#5 Posted : 03 July 2015 16:42:37
BigGrin Welcome to the forum MaxCool
#6 Posted : 03 July 2015 20:57:51
Hi Max,
Welcome to the Spitfire build you will love this build as it progress, and where you are at the moment building those wing tips just make sure that they are square it will make the metal plates fit better later on.
Hope to see your build pictures soon.
Trev.
max001
#7 Posted : 10 July 2015 05:58:58
Thank you one and all,I am not too hot on the computer my son will give me a hand to post some of the build,and yes my wing tips are good and straight. Just a little bit of info on me, my last build was 1/32 scale Hachette Lancaster I was in my seventies then,still am but getting close to that other number that comes after seven.I had
bissett send me 13 back orders got stuck into them now awaiting issue 16,have plated leading edge,I have only pinned along the leading edge pre drilled main spar for pins but will not pin till I have more plates,I like to have every thing nice and flush. I have waffled on a bit so I will shut up for now. Max
#8 Posted : 10 July 2015 07:37:30
BigGrin Welcome to the forum Max and happy building BigGrin
Ron
#9 Posted : 12 September 2015 12:44:52
Rank: Amateur Level 1
Ron
#10 Posted : 12 September 2015 12:47:25
Keep at it Max, I to am very late 70s but are attempting the build ,eyesight not perfect and fingers not so nimble , but must carry on and enjoy ,Regard's Ron
#11 Posted : 12 September 2015 18:28:51
Hi Max,
How's your build going you should be at about fitting the Leading edge all the way round to the wing tip, with mine I had to adjust the fit with a file so that first plate fitted, so turn it over and see if it looks square underneath, you must be about to fit your first plate one of many.
Trev.
#12 Posted : 13 September 2015 00:13:13
Hi Max and a warm welcome to the forum... You've chosen to build a fabulous model in the Spitfire and am sure you won't be disappointed.... Hope we do get to see some of your work real soon....Cool Cool
ALW
#13 Posted : 15 September 2015 08:31:30
Hello Max
Yes welcome. I've just finished pack 8 and looking forward to the metal components.
Some photos would be good-nice to see other builders progress.
By the way my uncle lives in Adelaide-a ten pound Pom!
Cheers
This page was generated in 0.318 seconds.
