Carb boot tear Options
CacoDeamon
#1 Posted : 03 July 2015 13:59:28
Rank: Newbie
Hi,
Have just run my first tank through at idle for engine break-in (yay, been long time waiting to hear it fire up).
After break-in thought time to check electrics again, noticed end of the carb throttle boot is almost tearing completely off at 75% throttle.
Has anyone else had similar issue... if so might look at after market instead of chasing a replacement.
#2 Posted : 03 July 2015 14:26:31
It's not a problem that has been reported on this forum
CacoDeamon
#3 Posted : 03 July 2015 15:35:45
Rank: Newbie
Must have got a defective one, will chase up a replacement.
Underside of boot also has hole same size as one on top in photo, both at the end pleat.
AcE_w1zArD
#4 Posted : 05 July 2015 16:08:57
Yeah looks to be defective. I just manually operated mine as the RC gear isn't connected to the carb yet, but there was plenty of stretch left in the rubber pleats.
roywhitworth
#5 Posted : 21 June 2016 20:38:59
I've just finished zeroing the servos and have noticed I have the same problem. Is this likely to cause problems at all?
Done: McLaren MP4/23
Started: Red Bull RB7 & Hachette 1/16 Tiger I Tank
Awaiting Construction: DeAg 1/12 Spitfire & RMS Titanic (Hachette)
Jors
#6 Posted : 30 June 2016 16:07:06
Mine is also torn
roywhitworth
#7 Posted : 22 July 2016 16:03:13
Well seeing as there was no reply here I brought another. Hopefully this one will be okay
#8 Posted : 22 July 2016 16:53:42
Simply contact custommer services to request a replacement carb stating the issue number it was supplied in.
Often if the Servo is not correctly set or its control rod not correctly aligned with the carb slider, the servo can overpull the carb slider leading it to overstretch the bellows and it split.
Three reports of a spilt bellows does not equate to all, of which there are many hundreds that have completed and run the RB7 thus far and c/s not receive any complaint about this.
This page was generated in 1.283 seconds.
