13 Pages «<910111213>
Dominick's Build Log Options
DSoldano
#201 Posted : 04 July 2015 00:05:09
Now the sides...
DSoldano attached the following image(s):
Dominick
On the Bench: DeAgostini HMS Victory, Moebius Creature From The Black Lagoon
Up Next: We'll See
DSoldano
#202 Posted : 04 July 2015 00:06:47
Dominick
Up Next: We'll See
DSoldano
#203 Posted : 04 July 2015 00:07:24
Dominick
Up Next: We'll See
DSoldano
#204 Posted : 04 July 2015 00:08:25
And finally, the stern area...
Dominick
Up Next: We'll See
Gauncer
#205 Posted : 04 July 2015 01:15:49
Brovo. Love all the pictures and info you post. I have been following from the beginning. I just got my HMS Victory and I like seeing you come together. JG
In the workshop: HMS Victory
Finished builds: Providence Whaleboat
DSoldano
#206 Posted : 04 July 2015 05:28:25
JG,
Thanks m8, hopefully my posts will help others but I've gotten some great advice and helpful hints from many in here. When you start your build, start a log, the advice and help has been very well worth it for me.
And best of luck to you on your build. Go slow, and don't be afraid to ask questions.
Cheers
Dominick
Up Next: We'll See
#207 Posted : 04 July 2015 09:48:29
Lovely work Dominick, looking great....Cool Cool
#208 Posted : 05 July 2015 08:18:09
BigGrin Looks great now the meat is going on the bonesCool
#209 Posted : 05 July 2015 12:28:02
BigGrin Looking good Dominick ThumpUp
#210 Posted : 05 July 2015 12:44:30
#211 Posted : 06 July 2015 13:32:49
Hi dominick.
Planking is looking good, keep the pictures commiong. IanBigGrin
DSoldano
#212 Posted : 06 July 2015 19:57:25
Thanks Gents,
I'm hoping to get the first set of cannon ports measured, marked, and cut over the course of this week.
Dominick
Up Next: We'll See
DSoldano
#213 Posted : 14 July 2015 21:06:37
Folks,
Sorry, it's been slow going this last week between the holiday, work, and having a friend in town for a visit. I managed to get the frames marked but that's as far as I've gone regarding Victory construction. I did assemble a waterline marker which should help with keeping some of the cannon ports parallel to the waterline.
Hopefully I'll get further this week but I haven't given up.
Dominick
Up Next: We'll See
DSoldano
#214 Posted : 16 July 2015 03:40:20
Alright M8s,
Gun ports marked and I thought I'd post a few photos here and get some feedback before I drill and cut. So here they are, 1 per post since I am on the iPad again.
One side
Dominick
Up Next: We'll See
DSoldano
#215 Posted : 16 July 2015 03:41:04
And the other
Dominick
Up Next: We'll See
DSoldano
#216 Posted : 16 July 2015 03:41:39
And a close up
Dominick
Up Next: We'll See
#217 Posted : 16 July 2015 09:07:56
Looking good, gun ports look spot on, well done......Cool Cool
#218 Posted : 16 July 2015 12:31:13
Hi Dominick.
Progressing nicely, look forward to seeing more of your build.
Ian Cool BigGrin
DSoldano
#219 Posted : 16 July 2015 15:22:31
Thanks Ian and Alan,
Now I can start cutting them. I also saw the DeAgostini billed for month 4 so that should arrive in about a week. My original plan was to try to keep up but I will probably fall behind, and even further when I tile the hull but no worries, I'd rather go slow and end up with a great result.
One quick question though, when I drill and cut the gun ports at the bow, I assume the cannon should stick straight out to the side (90 degrees to the keel), correct? Should the gun port sides be 90 degrees to the keel as well or 90 degrees to the curvature of the planks?
More to come soon.
Dominick
Up Next: We'll See
#220 Posted : 18 July 2015 10:14:40
More to come soon.
Hi Dominick, don't be too surprised if you fall behind when month 4 arrives, there is a lot of work to be done in that month.. Important thing is to enjoy your build, take your time to achieve the results you want as after all it's not a race you've entered but a fabulous journey.
As for the bow gun ports, simple answer is the base of the port should be parallel to the water line and the gun port sides should be 90 degrees to the base of the port....
Keep up the good work, will be following....
Guest (20)
This page was generated in 0.571 seconds.
