32 Pages «<1819202122>»
tf64 Spitfire Build Options
#381 Posted : 03 July 2015 23:01:08
Hi Trev BigGrin
Looking good.
DaDokta
#382 Posted : 03 July 2015 23:59:15
Love your build,
Walter
Greetings,
Walter
Present builds:
Revell B-24D Liberator 1:48
On the shelf:
Completed builds:
#383 Posted : 04 July 2015 08:58:47
Steve,
Thanks for looking, hope to do another update today.
Trev.
#384 Posted : 04 July 2015 09:00:35
Dave,
Pleased to see you are enjoying my build.
Thank you.
Trev.
#385 Posted : 04 July 2015 09:12:11
She's coming along nicely and looks like your enjoying the build Cool
#386 Posted : 04 July 2015 09:17:08
Derek,
This is a great build Derek, there should be more build diaries for this type of aircraft, if you take your time it will all go together with out problems. The most demanding part for me is fitting the metal plates but the most stimulating.
Looking forward to seeing your DC3 build Derek and I know you will do it the justice it deserves.
Trev.
#387 Posted : 04 July 2015 09:24:25
Walter,
Thanks for your comments always grateful to hear from you, I see you are colleting the Spitfire will this be the De-Ago build.
Trev.
#388 Posted : 04 July 2015 15:10:24
Thank you Mr T for your comments.
Trev.
#389 Posted : 05 July 2015 10:03:48
UPDATE:SPITFIRE.
050715.
UNDERCARRIAGE ASSEMBLEY.
In Brief,
I found this section went together very well, I did have to file the Strut mounting blocks to fit into the wood housing but that was all. I chose red for the Strut blocks and black for the suspension legs.
I found drilling the a shallow 2mm hole in the wheel fairings ok but take care as the material is very soft, with to much pressure you can slip, so the best bet is to support the fairing or use a bench drill.
I then fixed the wheels and aligning the holes with the with the fairings and tighten all 4 screws, then assemble and placed in one piece back into the landing gear housing applied glue to the red struts and glued in place.
There should be a gap of 130mm between fairing edges, I will in need adjust when fitting landing gear servers.
Undercarriage Assemble.
This shows Strut Mounting Blocks/Suspension leg test fitted not glued.
Wheel Fairings ready to be assembled.
This picture shows the Undercarriage Assemble complete.
Undercarriage now in place.
Final movement check there should be a gap between the Fairing edges of 130mm,this will be checked when I join both wing together and fit servers.
More soon thank you for your time.
Trev.
#390 Posted : 05 July 2015 10:22:42
Looking good Trev, your build is moving along very nicely indeed....Drool Drool .. Look forward to your next update...
#391 Posted : 05 July 2015 11:53:05
Nice work Trev, and well done on gaining the purple medal for making 1000 posts, well done!
#392 Posted : 05 July 2015 19:14:42
BigGrin Lovely work there Trev looking good Cool
#393 Posted : 05 July 2015 19:21:17
BigGrin Looking great Trev and congrats on the medalCool
mark 2
#394 Posted : 05 July 2015 22:49:49
Hi Trev BigGrin .
Your build keeps going from strength to strength.
Fantastic work as all ways and I look forward to more of the same.
Best regards.
#395 Posted : 06 July 2015 21:25:09
Alan,
Thank you for looking, the pace seems to be moving on now Pack 23 is on it's way, I have just fitted the metal plates to the wing tips, next should be the electric's.
Trev
#396 Posted : 06 July 2015 21:27:28
Hi Martyn,
How are you are well, and thank you for looking and your comments.
Trev.
#397 Posted : 06 July 2015 21:32:30
Andy,
Thanks for your time, when you receive a personal award for the Forum as a medal it goes a long way (even at my age)
Trev.
#398 Posted : 06 July 2015 21:38:08
Lovely work as always Trev, she's really starting to look the part now and I bet you can't wait to start on the electrics as that will suddenly bring it all to life? Love the little red parts too, adds a nice accent to the undercarriage bays and certainly attracts the eye.
Congrats on reaching 1000 posts as well mate and a very well deserved purple medal. Cool ThumpUp
#399 Posted : 06 July 2015 21:47:07
Hi Mark,
Good to hear from you and thank you for your nice comments.
Mark did you know that there will be a new Model Shop opening in St George' walk Croydon in about two week time ?
Trev.
#400 Posted : 06 July 2015 22:05:37
Hi Kev,
Thanks for your time, it is important to me when you receive comments about your work such as yours and the other guys it makes you try even harder on your next update, yes your right about the sparks cant wait till the weekend to start. At the moment I am building a small off shore fishing boat called the Norden this is for my Daughter this I fit in week nights plus the washing up to keep the wife sweet.
Trev.
