8 Pages «<34567>»
Dans MP4/4 Build Options
dandare
#81 Posted : 03 June 2015 21:20:15
most Welcome
make sure you post some piccys your progress BigGrin
Dan
dandare
#82 Posted : 23 June 2015 16:42:28
well i made a start on the floor, filled some of the sink marks that i thought would still be visible, then proceeded to base coat ready for the carbon decals, alls good. I applied the decals and left for a few days just to make sure everything was good and set. i then masked off some of the areas on the floor and gave all the decals a light over spray of transparent smoke! then an extremely thin coat of matt black just to tone down the bluish effect of the smoke so the decals just barely came through. piccys are pre transparent smoke & black.
dandare attached the following image(s):
dandare
#83 Posted : 23 June 2015 16:46:46
one slight problem!!!!
as i peeled back the masking tape a couple of sections of the decal decided to come with it ?????
so that pretty much ruined all my work Cursing
so long story cut short, sink hot water soft scouring brush, re mask, matt black and im happy!
dandare
#84 Posted : 23 June 2015 16:50:01
just need to scuff the floor a little more!
i also added a few extra detail parts to the right side pod having followed my Mp4/4 detail booklet.
Dan
dandare
#85 Posted : 23 June 2015 16:51:38
and then proceeded to make a start on the brake hoses
only just started these but thought it would be worth sharing
Dan
Steve279021
#86 Posted : 23 June 2015 18:33:06
the detail on that right side pod is absolutely outstanding, well done.
Dodge charger build complete
dandare
#87 Posted : 23 June 2015 18:49:47
Thank you Steve Blushing very kind comments
unfortunately the old camera is not the greatest
i think ive managed to find a setting that allows close ups, so here are a few more!!!
although any little speck of dust is now really highlighted!! will have to get the old Vacuum on it before the next set of photo's Laugh
Dan
#88 Posted : 23 June 2015 18:54:05
BigGrin Looks great DanCool
Phil
#89 Posted : 23 June 2015 19:25:27
Looks great! The CF has come out nice. Which colour did you use underneath the CF?
Building the MP4/4!
#90 Posted : 23 June 2015 22:02:53
Looking good Dan. The setting you found sounds like macro mode, as you have found the only problem is it does show up every tiny speck of dust Cool
dandare
#91 Posted : 24 June 2015 08:51:23
Hi Andy, thanks for looking in
Dan
dandare
#92 Posted : 24 June 2015 08:53:34
Hi Phil
thanks for looking in, i had originally used a mix of aluminium & gun metal, however once the decals decided to peel off i reverted back to good old Matt black and No decals.
Dan
dandare
#93 Posted : 24 June 2015 08:55:33
Hi Dave
Thanks for looking in, for the life of me i swear there was no dust prior to taking the pic Confused clearly that macro setting does indeed pick up anything micro LOL
Dan
DaDokta
#94 Posted : 24 June 2015 10:22:48
Great Detail! Love your build!
Walter
Greetings,
Walter
Present builds:
Revell B-24D Liberator 1:48
On the shelf:
Completed builds:
dandare
#95 Posted : 26 June 2015 00:51:42
Walter
Thank You Walter
very kind of you & thank you for looking in
Dan
NSXKid
#96 Posted : 26 June 2015 04:33:47
Dan,
Awesome work!! Sorry I'm going to steal more of your creativity!! Did you use shrink tubing on some of those extra hoses/lines?
Jim
dandare
#97 Posted : 26 June 2015 12:56:13
NSXKid wrote:
Dan,
Jim
Hi Jim
feel free! thats why we all post here. so others can be inspired BigGrin
i have used shrink tube on the pipe coming from the top of the intercooler, however ive just ordered and recieved some tubing (1.7mm) from Hiroby to replace it as the shrink tube just does not look good imo.
the other tube/pipe is similar to the pipe used in the kit on the brake lines, again this came from Hiroboy.
ive also just received a smaller diamater pipe to change the radiator overflow pipes.
Dan
dandare
#98 Posted : 26 June 2015 12:58:16
dandare wrote:
NSXKid wrote:
Dan,
Jim
Hi Jim
Dan
sorry the Electrical plugs used thin guage black wire
Dan
casino
#99 Posted : 10 July 2015 20:21:53
love the extra detail on the side pods Dan, looks very nice indeed.
shame about the floor decals as i haven't made my mind up yet on what to put on the floor, i have a load of fine carbon decal here which i was going to try and i understand why you smoked it down.
C
dandare
#100 Posted : 12 July 2015 20:08:01
C
Thanks for the comments Casino, having had the decals then having to revert back, im much happier with the matt black finish.
Dan
8 Pages «<34567>»
This page was generated in 0.463 seconds.
