8 Pages «<45678>
Dans MP4/4 Build Options
dandare
#101 Posted : 12 July 2015 20:10:55
added some braided lines to replace the kit versions, albeit some pictures ive seen have the lines taped up in a metal foil type of tape! others the lines are visible.
Dan
dandare attached the following image(s):
#102 Posted : 12 July 2015 20:20:57
BigGrin Looks great DanCool
NSXKid
#103 Posted : 13 July 2015 00:45:26
Looks great. Yes Dan I saw the same thing with the brake lines wrapped too in some of the pics. Did you only cut off the kit's brake lines and just add the braided lines? or is the entire piece all scratch built bits?
I was trying to use the leftover foil to wrap on the brake lines but it doesn't stick very well. I was also trying to slide some small braided lines over the existing kit's lines but can't fit it over the piece.
dandare
#104 Posted : 13 July 2015 18:36:40
thank you
waiting desperately for the main body Cool
Dan
dandare
#105 Posted : 13 July 2015 18:44:22
Hi Jim
i used the kit brake lines, just cut off the main pipes, i used some hose ends from RB Motion & hiroby and used a braided line that slipped into the ends for a neat look! with the banjo end of the brake line i just drilled a hole and inserted the braided line as there a little less prominent.
you could try some bare metal foil if you want the taped up look
http://hobby.uk.com/bare-metal-foil-matt-aluminium.html
Dan
DaDokta
#106 Posted : 13 July 2015 20:31:03
Love your detailing!
Walter
Greetings,
Walter
Present builds:
Revell B-24D Liberator 1:48
On the shelf:
Completed builds:
NSXKid
#107 Posted : 13 July 2015 22:57:53
Thanks for the info.
On a side note, did you paint the clutch packs? I'm going to paint mine based on the pics I have. They have a bronze color to them (not sure if they are bronze 'brand new' or if they turn color over time on the real car?).
Steve279021
#108 Posted : 14 July 2015 12:34:33
thank you
Dan
Me too. I bet it wont be until the last pack! Your build's coming along nicely DanThumpUp
Dodge charger build complete
Senna lotus 97t complete
#109 Posted : 14 July 2015 13:24:51
Nice work Dan, some superb detailing going into this - very well done. Cool ThumpUp
dandare
#110 Posted : 14 July 2015 20:27:14
Walter
Thank you Walter
Dan
dandare
#111 Posted : 14 July 2015 20:29:32
Jim
i left the Clutch as is, since its completely hidden once assembled to the engine
Dan
dandare
#112 Posted : 14 July 2015 20:30:54
Steve279021 wrote:
thank you
Dan
Thank you Steve
your probably right, always leave the best bits till last LOL
Dan
dandare
#113 Posted : 14 July 2015 20:31:38
Thank you Kev
kind words
Dan
cooper_s_1275
#114 Posted : 18 August 2015 14:31:05
Dan
if I can choose my expression, this is going to be one of the biggest WOW in my experience... you won't be able to imagine how much I admire your work and how much life you've put into this legendary machine!!!!
I wish I have the skill to replicate half your work!!!
very nice brake!!! what size is your braided lines?? and where can I get them?? do they do mail order??
dandare
#115 Posted : 19 August 2015 10:36:38
cooper_s_1275 wrote:
Dan
very kind comments Cooper_s_1275 Blushing although my skill set in comparision to many of the superb modellers on the forum is very small.
im not completely sure what size braided line i used think it was .6mm with the brake fittings to suit (ill check the packaging later) braided lines can be sourced from "detail master" or "hiroboy" and i got the fittings from RB Motion.
Many Regards
Dan
dandare
#116 Posted : 19 August 2015 20:53:12
Dan
Many Regards
Dan
Cooper_s_1275
Braided brake line was detail master 1.14mm pt no DM1304 & the "Rad hose ends" came from rb motion pt no 1529
Dan
dandare
#117 Posted : 11 October 2015 10:26:40
well its been a while, and i don't have much to post. been way to busy to do any modeling lately and was waiting on some replacement parts from Degostini, which i have to say where fantastic in getting the parts to me very quickly with no hesitation whatsoever. Fantastic job Customer services thank you.
well with the new parts arrived and a bit more time hopefully i will post some more progress in the next few days.
well given the limited time and parts ive only managed to paint up the Turbos, heat ex-changer, header tank & Plenum chamber.
Dan
dandare
#118 Posted : 11 October 2015 10:33:05
dandare
#119 Posted : 24 October 2015 15:09:33
managed to get the exhaust assembled and all painted up, fitted to the engine and all the assembly fitted to the mono. Added some brackets to the intercooler pipes.
RM1
#120 Posted : 24 October 2015 15:28:27
Looking good. The extra details are excellent.
May I ask what paints you used on the exhaust pipe?
Malc.
8 Pages «<45678>
This page was generated in 0.252 seconds.
