15 Pages «<7891011>»
steve's build Options
Steve279021
#161 Posted : 08 July 2015 22:39:44
I thought whilst waiting for the next pack and now that I've got all 4 wheels and tyres then I'd take the opportunity to 'rough' up the tyres. I used 1500 grit and wish I'd used 800 as was advised as it took ages. But I'm happy with the result.
Before
After
Dodge charger build complete
#162 Posted : 08 July 2015 23:23:47
BigGrin Nice result, I will be doing the same with mine
#163 Posted : 08 July 2015 23:51:27
Great result on them tyres. Would be great if it could have the rubber bobbles on them too.
Chris
JD4EVER
#164 Posted : 09 July 2015 00:41:56
Tyres look really good,how did you get such a good finish and also such an accurate line around the the edge of the tyre?
Steve279021
#165 Posted : 09 July 2015 07:50:39
The finish was achieved by using a finer grade of paper but it took longer to do. I used 1500 grit. It's not hard to get the line at the edge as long as you keep the paper flat across the tyre when rubbing and not go round the edge onto the side wall and I always rubbed in a linear motion and not across the tyre face.
RM1
#166 Posted : 09 July 2015 07:59:58
Excellent result on those tyres.!
Steve279021
#167 Posted : 11 July 2015 15:39:14
Pack 15 here now. Getting moving with the engine now.
#168 Posted : 11 July 2015 16:06:59
Excellent work so far Steve, this is turning into one to watch.Very nice build, all very neat and tidy and those tyres look fabulous, they will certainly add a nice touch of realism to the finished model - very well done!!
I think you made the right choice to use the finer grade abrasive even though it took longer? If you had used the more coarse grade it could possibly have torn the surface of the vinyl tyres and ended looking a little rough, but yours looks spot on - nice job sir!! Cool ThumpUp
Steve279021
#169 Posted : 11 July 2015 16:12:02
Thank you very much kev
Glad you like itBigGrin
#170 Posted : 11 July 2015 17:48:02
That's a hell of a difference with the tyres, they look so life like now, awesome job ThumpUp
#171 Posted : 11 July 2015 18:32:30
BigGrin Nicely doneCool
DaDokta
#172 Posted : 11 July 2015 22:00:40
Nice finish to the tyres!
Greetings,
Walter
Present builds:
Revell B-24D Liberator 1:48
On the shelf:
Completed builds:
Steve279021
#173 Posted : 12 July 2015 15:44:12
Thanks for the comments.
Steve279021
#174 Posted : 13 July 2015 21:11:53
Engine underway. Cam cover bases and intake manifold bases fitted.
Steve279021
#175 Posted : 14 July 2015 23:06:29
Front, back and sides on the engine now.
Got a bit of an issue with fitting 1 of the plugs top the right cam cover.
Steve279021
#176 Posted : 15 July 2015 21:14:22
Stage 50 finished. Cam covers and plugs fitted.
Steve279021
#177 Posted : 15 July 2015 21:37:37
Engine lower sides fitted.
#178 Posted : 15 July 2015 22:43:40
BigGrin Looking goodCool
Steve279021
#179 Posted : 16 July 2015 21:25:21
Stage 51 done. Intake manifolds, connector on left radiator housing and gearbox hose fitted.
Steve279021
#180 Posted : 17 July 2015 23:27:31
Stage 52 started. Water pumps, oil pump and engine bottom.
Guest (8)
This page was generated in 0.208 seconds.
