18 Pages «<1213141516>»
#261 Posted : 21 July 2015 22:21:54
BigGrin Thank you everyone for looking in and your comments, more soonCool
#262 Posted : 22 July 2015 12:39:42
Hi Andy.
Gallery and paint job looks realy nice. look forward to seeing yhe next instalment. Ian Cool Cool BigGrin
#263 Posted : 22 July 2015 21:10:40
BigGrin Hi Ian, Thanks for looking in and your commentsCool
#264 Posted : 26 July 2015 20:58:14
The bow headrails/furniture has now been added along with some more decoration on the roundhouse bulkhead. Next job will be to make up the 24 gum carriages and 18 pounders with flintlocks that go on them along with all the other deck furniture and windlass. Then the upper deck goes on. I have also found out that the Agamemnon although classed as a 64 gunner, third rate she also carried 12, 24 pound carronades that were not counted as being part of her gun compliment. So this would make her a 76 gunner and nelson wanted a 74 when he got the Agamemnon Blink LOL. More soon.
der Gohfelder
#265 Posted : 26 July 2015 21:11:23
Hi Andy!
A nice work as always! Isn´t it very fragile?BigGrin
Regards, Bernd
#266 Posted : 26 July 2015 21:12:58
#267 Posted : 26 July 2015 21:13:13
Absolutely Awesome Andy. Your doing a great job.
chris
#268 Posted : 26 July 2015 22:32:58
Great build Andy.
Trev
#269 Posted : 26 July 2015 23:46:08
BigGrin Thanks everyone for looking in and your comments the railing may look a little delicate but its stronger than it looks. I forgot to add that the parts from the kit were all flat so for the first time I tried some carving on some of the parts came out quite well I think.Cool
#270 Posted : 26 July 2015 23:50:54
Splendid work as usual Andy ThumpUp
#271 Posted : 27 July 2015 00:32:37
Looking superb Andy. Also looks as if there is some real complex wood bending going on to get the beak looking just right and your carving skills certainly enhance it all. An excellent result.... Drool Drool
#272 Posted : 27 July 2015 08:08:35
BigGrin Wow lovely work on the bow Andy looking brill BigGrin
#273 Posted : 27 July 2015 16:33:38
BigGrin Hi Dave,Alan and Martyn
Thanks for looking in and your comments, there is still a little more decoration on the bow yet but I ran out of the cast decoration and have just ordered more from Caldercraft along with some carronades.
#274 Posted : 01 August 2015 00:00:09
BigGrin BigGrin Hi All
Just a small update, I have started making up the central gratings/stairwells and capstan. The capstan is made up from a piece of dowel and several pre-cut parts this left the top flat and it did not look right so I added another disc to the top and shaped it to get the curve on the top.
The capstan has been painted and just needs the cannon balls added to the racks the gratings have yet to be painted and again cannon balls added to the racks. The froward ridding bitt as supplied [pre-cut 5mm walnut] will need to be widened to accomadate the stove but the normal bits should be fine. Next it will be to make up the two ladders down to the main gun deck and the gun carriages for this deck. More soon.
#275 Posted : 01 August 2015 00:03:57
Coming along Andy, looking great... Must admit, agree with your decision to change the top of the captstan, flat tops just don't look right.... Great job you've done....Cool Cool
#276 Posted : 01 August 2015 09:34:57
BigGrin Hi Alan
#277 Posted : 01 August 2015 10:04:24
Lovelynwork Andy, I agree with Alan the rounded capstan does look much nicer Cool
#278 Posted : 01 August 2015 16:14:07
BigGrin BigGrin Hi Dave
#279 Posted : 01 August 2015 16:34:46
I ran out of the soft metal cast and shaped rods so I ordered some more from Caldercraft which arrived today along with the 24 lb carronade kit I ordered. Caldercraft do kits that contain the parts for two carronades in 18lb,24lb and 32lb with working screw adjustment they also just sell the turned brass carronade barrels. The kit comes in a plastic bag with the barrels and etch parts in a separate compartment to the wooden and other parts along with a double sided set of comprehensive instructions. The barrel and etch parts are nicely finished but the wooden parts suffered a little from the ravages of the postman, a couple of the parts getting separated from the fret but no damage to the parts themselves. Altogether a nice little kit.
I have already mentioned that the Agamemnon carried 12 carronades above her normal compliment of guns. I think I may get 6 altogether and have them on the forecastle where there are no guns mounted. More soon.
daffy09
#280 Posted : 01 August 2015 17:26:26
Those carronade kits look really good Andy, they'll certainly look good on her deck. You did a good job of the capstan, I agree that it wouldn't have looked right with a flat top.
Happy building
David
This page was generated in 0.358 seconds.
