wiring up for lights at night Options
bripfc
#1 Posted : 15 September 2010 12:25:32
hi all new to this but i was thinking of puting light inside the build,as ive seen it done on other builds but not sure of the best way of doing this. Can any one give me any ideas, had thought about puting in flashing exmas lights in be hind the gun ports,but would like to light the back cabin as static lights ?
Any help or ideas would be a help
Thanks BrianBigGrin
Brian
Current Builds
HMS Victory
HMB Endeavour
HMS Hood
PLAY UP POMPEY!!!no wise cracks
Mac
#2 Posted : 15 September 2010 12:36:32
Welcome aboard Matey!BigGrin some of the guys were discussing this a couple of months ago but no one has got round yet to posting details wiring diagrams etc as things have been a bit crazey round here. But there is a lot of expertise on this forum so no doubt one of the guys will be along to help u in a bit.
Pam's shipyard is closed for now no more room!
riff-raff
#3 Posted : 15 September 2010 16:47:11
I have started just using simple LEDs from Maplins
http://forum.model-space...t.aspx?g=posts&t=993
Built:
Mac
#4 Posted : 15 September 2010 17:03:47
[quote=riff-raff]I have started just using simple LEDs from Maplins
http://forum.model-space....aspx?g=posts&t=993[/quote]
U no matey I must be getting dafter in my old age BigGrin Of course u put Leds in ur cutaway in August Blushing Sorry!
riff-raff
#5 Posted : 15 September 2010 21:55:02
Just finished wiring the LEDs to the mains via a 12v power pack. I was using a 12v battery box that I didn't like as I would have to have access to the pack to change the batteries. I have used the power pack from an old radio which plugs into the ship via a round 6mm socket so all I have to do is mount the socket somewhere discrete.
I have mounted the LEDs using small block connectors. That way I can bend the LED wires into the exact position that I want them in. I just run the wires where they can't be seen. Obviously this does require some drilling of the gun decks.
If you are going to follow this example - the best tip is to use very thin wires as you need to bend some round tight corners.
Another tip - if you are buying your LEDs from Maplins, decide roughly how many you need. They only stock 2 - 4 of any kind !!!!
Built:
bripfc
#6 Posted : 16 September 2010 09:06:20
thanks for the adivce Riff Raff this is a great help as ive got an old dolls house lighting transformer that i will use,did try some of the dolls house bulbs as well but found these were to bright,if pos can you let me know the Maplin part No of the led,s you used,and do they do them in flicker styleLOL .
Thanks BrianBigGrin
Brian
Current Builds
HMS Victory
HMB Endeavour
HMS Hood
snowtiger
#7 Posted : 16 September 2010 13:36:30
Hi bripfc.....i do not know if they do a flicker l.e.d.....but you can get a variable resistor .....that will dimm the bulbs....they work like a dimmer switch...hope this helps...BigGrin
.John...
bripfc
#8 Posted : 16 September 2010 14:09:47
thanks for that snowtiger have found some that flash from maplin might give these a go see if work, has any one got a diagram of whow to run the wiring insde Laugh
Brian
Current Builds
HMS Victory
HMB Endeavour
HMS Hood
riff-raff
#9 Posted : 16 September 2010 15:58:23
I just run them where I can - I decide first where I want illumination fix the LED to a block connector and then just run wires where I can.
Numbers on the pack of LEDs are:
63.05.B4 CJ68
048-0077483
Hope this helps mate
Built:
bripfc
#10 Posted : 18 September 2010 14:36:04
Hi rif raf did you put any resistors in the wiring for led as ive got some led from maplin and i had a dolls house transformer 12v it ca take up to 35 lights but tried it an it blew the leds any ideas why?
any help or ideas would be good
Cheers brian
Brian
Current Builds
HMS Victory
HMB Endeavour
HMS Hood
riff-raff
#11 Posted : 18 September 2010 14:59:51
I did at first when I used 6v LEDs but then I changed to 12v LEDs with a 12v power supply.
Built:
bripfc
#12 Posted : 18 September 2010 17:12:17
does any know what type of resistor i would need to use as have bought all the led i need, the other half wasnty to happy then, so hate to think what she will say if have to replace again?
Brian
Current Builds
HMS Victory
HMB Endeavour
HMS Hood
This page was generated in 0.069 seconds.
