2 Pages 12>
HMS Surprise queries Options
hudsonrobert49
#1 Posted : 15 September 2010 14:32:09
magpie1832 wrote:
Hi Robert.
Looking good.
The Sapele is like the Mahogany on my san francisco 2, To get it to bend easily I left the plank in boiling water for a couple of minutes, then if you have an elecy plank bender get the bend with that, if you don't have one I used my wife's iron to do it. It works a treat and saves on breakages of the wood. ( the ends with a major bend like the first 2 planks at the rear just soak for 15 minutes will allow you to bend and twist them..
Hope you don't think I'm interfering..
Cheers Chris..
Looking at all of the pictures here are the planks supplied in one long length to go from stem to stern or are they shorter lengths please?
Only asking because I am not sure when I eventually get mine what to use to soak them in. Not sure a washing up bowl would be large enough. Any suggestions would be appreciated.
Kind regards
Tony
Don't let go of your dreams. If you have determination and belief in your dreams, you will succeed in spite of your desire to let go.
Rob
Bridlington.
hudsonrobert49
#2 Posted : 15 September 2010 14:39:23
Should be spelt general, and not what I put.
They come in two pieces and you butt join them.
Rob
Bridlington.
#3 Posted : 15 September 2010 14:49:43
Good Idea there Robert, Saves making our Build logs Massive..
Chris..
hudsonrobert49
#4 Posted : 15 September 2010 14:55:59
Thanks magpie m8.LOL
Rob
Bridlington.
hudsonrobert49
#5 Posted : 16 September 2010 08:15:59
Hi all I have checked my Sapele planks and some are damaged, any one else have this problemConfused Confused Cursing Cursing
Rob
Bridlington.
#6 Posted : 16 September 2010 08:39:30
Hi Robert,
I would ring C/S for some more if I was you. How damaged are they.
Cheers Chris.
hudsonrobert49
#7 Posted : 16 September 2010 08:49:25
Hi Magpie m8 Nine of them are damaged at one end and damaged in the middle, and they all have the exact same damage. will post pics on here a bit later on.
PS could use them for infills if you know what I mean, but that's not the point.
Rob
Bridlington.
#8 Posted : 16 September 2010 11:10:42
Lets just hope that there's no other Damaged parts then Robert.
Chris..
hudsonrobert49
#9 Posted : 16 September 2010 14:17:41
There nine but only done two soz about the out of focus pic but you can see see what i mean, they are the same two planks. what you gonna do!!!
Cursing Cursing Cursing
Rob
Bridlington.
#10 Posted : 16 September 2010 15:12:25
Hi Robert,
Hopefully you can use them up but it is a bummer...
I have cancelled issues 7 and 8..... My next delivery will be 9 and 10. So I will order Walnut planks for mine. .
Cheers Chris..
hudsonrobert49
#11 Posted : 25 September 2010 11:03:48
Hi When I pin the Sapele planks to the Hull I blunt the sharp end with a file so that the pin tears though the wood that way the pin does not go between the grain and split the wood, (works for me) But be careful at the the but ends of the planks they will split there.
Try it on a spear piece!
Rob
Bridlington.
hudsonrobert49
#12 Posted : 17 November 2011 11:00:22
Cursing Hi ALL, they have sent me Build instructions for part 22, BUT there is NO build instructions lol, can any one help me Please.
ps iam going to start building again, ive JUST finished the gun ports.
Robert
Rob
Bridlington.
Castos
#13 Posted : 19 August 2012 14:56:06
Good Day
I am planning to build the Surprise. Can any tell me how many issues are there for the complete build.
Thanks
Castos
Current Build: HMS Victory
Built: HMS Bounty
Next Build: Sovereign of the Seas Started collecting. Redrawing of plans for Santisima Trinidad for a scratchbuild. Santisima Trinidad - waiting for launch.
#14 Posted : 19 August 2012 16:48:41
go to the de-ag shop all info on there.http://www.model-space.com/gb/ships/our-model-ships/hms-surprise/
harty
#15 Posted : 19 August 2012 16:57:23
There are 28 issues in total either in 14 x2 installments or 28 monthlyBigGrin
#16 Posted : 19 August 2012 19:30:41
Depending on what you choose to sign up to, the offer is either 28 monthly delivery's of 4 parts/issue sets, or 14 monthly delivery's of 4 parts/issue sets.
hudsonrobert49
#17 Posted : 22 October 2012 09:27:36
don't laugh but I've forgot how to upload photosLOL
Rob
Bridlington.
hudsonrobert49
#18 Posted : 14 November 2012 09:41:21
Hi can ANYONE Help me please, has anyone had the pedestals for HMS Surprise yet if so what do they look like eg do the have holes in the middle so you can fix them to the baseboard and ship???.
As mine have NOT!.
Rob.
Rob
Bridlington.
#19 Posted : 14 November 2012 10:06:13
Unusual not to have locating holes or pins, but may be they are intended to be glued to the display base with such as epoxy, though if it were me, I would drill the base and into the pedestals, then secure with a self-tapper and glue.
Tigger49
#20 Posted : 14 November 2012 10:19:55
Rob,
Build instructions 21 cover dispatches 21, 22 and 23, the next build instructions come with dispatch 24.
Andre
Building:
DeAgostini:
HMS Victory
HMS Surprise
H.M.S Victory Cross-Section
2 Pages 12>
This page was generated in 2.051 seconds.
