spitfire skin Options
m0325
#1 Posted : 30 July 2015 00:30:16
Where can you purchase spare aluminum sheets so that you can make modified skin area to make up for poor fit of standard skin provided with the kit?
greyhawk
#2 Posted : 30 July 2015 01:26:18
You can get aluminium sheets at any building supplies store like Home Depot.
This one should be thin enough for instance
http://www.homedepot.com...-Sheet-801487/204225785
Of course modeling hobby stores should also carry them (at inflated prices)
m0325
#3 Posted : 30 July 2015 04:43:28
Thank you for your quick response. That ref for that number home depot is 21 gauge which is .034 inches or .873 mm. I thought in the spitfire kit the thickness was .28 mm or .011 inches. Am I wrong?
#4 Posted : 30 July 2015 09:03:29
The kit content provides a number of spare skin sheets across Stages 79, 88, 92 & 103
greyhawk
#5 Posted : 30 July 2015 12:26:03
Yeah, I linked the wrong one apparently, here the one I meant to link to
http://www.homedepot.com...um-Sheet-57507/205833444
This page was generated in 0.096 seconds.
