11 Pages «<45678>»
Gibbo's DeAgostini Victory Build Diary Options
Gibbo
#101 Posted : 30 July 2015 19:41:09
z8000783 wrote:
Nice work Paul.
It may not be a good idea to sand the planks too much, as you go, though. They are not very thick and it may be easy to over do it.
I know it tempting but better to wait until the end when you can treat it as the next project.
Thank you for the advice John much appreciated, and thank you for the magazine index you have created, i started using it last week and has come in very handy, it's a great piece of kit.
Cheers
Paul
Gibbo
#102 Posted : 30 July 2015 20:41:56
Stern planks have been shaped and stern gun-ports have been cut out along with the first row of gun-ports on the port side, now ready for the next lot of planking and second row of gun-ports.
Gibbo attached the following image(s):
Gibbo
#103 Posted : 30 July 2015 22:01:18
Another small update, forward bulkhead planked and sanded.
#104 Posted : 30 July 2015 23:47:11
Looking great Gibbo, you're doing a super job.....Cool Cool
#105 Posted : 31 July 2015 07:41:39
ThumpUp Cracking job Paul looking the biz Cool
#106 Posted : 31 July 2015 12:32:41
#107 Posted : 31 July 2015 12:55:57
Hi Paul.
Looking good .look forward to seeing your progress Ian.Cool BigGrin
Gibbo
#108 Posted : 31 July 2015 15:52:00
Ian, Steve, Martyn & Alan, thanks for the comments guys, always nice to get positive feedback, much appreciated.
#109 Posted : 31 July 2015 15:55:35
This looks like it's coming along quite nicely, great work ThumpUp
#110 Posted : 31 July 2015 19:22:04
BigGrin looks greatCool
nightwisher
#111 Posted : 31 July 2015 20:53:41
Excellent fairing Gibbo you can't go wrong with the planking on a base like that.
Had a dream to understand
A single grain of sand
He gave birth to poetry
But one day will cease to be
Gibbo
#112 Posted : 01 August 2015 01:17:06
When cutting out the forward gun ports with balsa behind them, cut them out as you normally would cutting the shape of the port with the centre hole and the triangle cross cuts, then using your dremmel with a ball attachment insert it into the hole and start working behind the planking on the balsa from the centre out, bits of the triangles will start to come away, take your time and keep going, don't use the Dremmel on the outside edges of the ports, always work behind them so you don't round anything off and the triangles will just pop out, sand off the sides as you normally would, paint black, job done.
#113 Posted : 01 August 2015 09:34:11
Nicely done Gibbo, looking good.....Cool Cool
#114 Posted : 01 August 2015 18:14:26
Nice progress looking great mate
#115 Posted : 01 August 2015 18:45:34
BigGrin Nice workCool
Gibbo
#116 Posted : 04 August 2015 23:29:19
Planking done up to layer 12, dummy cannon supports painted, cut and glued in place, broke the top of a couple of ribs with the sanding block while sanding but easily fixable, and then cut out the gun-ports.
#117 Posted : 04 August 2015 23:32:48
Looking really good Gibbo Cool
#118 Posted : 05 August 2015 00:41:15
Coming along Gibbo, very nice clean work....Cool Cool
nightwisher
#119 Posted : 05 August 2015 10:39:11
Nice planking Gibbo. I like the idea of cutting gun ports as you go, much better than being faced with a huge expanse of hull and trying to mark them out as on the sovereign. Cool
Gibbo
#120 Posted : 05 August 2015 11:18:35
Yeah it does make you feel like you're actually getting somewhere.
Cheers.
Guest (19)
11 Pages «<45678>»
