z8000783 wrote:Nice work Paul.
It may not be a good idea to sand the planks too much, as you go, though. They are not very thick and it may be easy to over do it.
I know it tempting but better to wait until the end when you can treat it as the next project. Thank you for the advice John much appreciated, and thank you for the magazine index you have created, i started using it last week and has come in very handy, it's a great piece of kit. Cheers Paul Building: DelPrado HMS Victory. Building: DeAgostini Sovereign Of The Seas.
Stern planks have been shaped and stern gun-ports have been cut out along with the first row of gun-ports on the port side, now ready for the next lot of planking and second row of gun-ports.   Gibbo attached the following image(s): Building: DelPrado HMS Victory. Building: DeAgostini Sovereign Of The Seas.
Another small update, forward bulkhead planked and sanded. Gibbo attached the following image(s): Building: DelPrado HMS Victory. Building: DeAgostini Sovereign Of The Seas.
Looking great Gibbo, you're doing a super job..... Regards Alan
 Cracking job Paul looking the biz Rgd Martyn Building ? Completed. Soliei Royal . Sovereign of the Seas . Virginia . Scotland . San Felipe . Corel vasa , Santisima Trinadad X section , Vasa Next Build ? When sailors have good wine, They think themselves in heaven for the time. John Baltharpe
Lovely progress Gibbo, looking good Steve
Hi Paul. Looking good .look forward to seeing your progress Ian. Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
Ian, Steve, Martyn & Alan, thanks for the comments guys, always nice to get positive feedback, much appreciated. Building: DelPrado HMS Victory. Building: DeAgostini Sovereign Of The Seas.
This looks like it's coming along quite nicely, great work
 looks great Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Joined: 09/12/2013 Posts: 577 Points: 1,748 Location: smethwick england
Excellent fairing Gibbo you can't go wrong with the planking on a base like that. Man he took his time in the sun Had a dream to understand A single grain of sand He gave birth to poetry But one day will cease to be Greet the last light of the library...We were here!
When cutting out the forward gun ports with balsa behind them, cut them out as you normally would cutting the shape of the port with the centre hole and the triangle cross cuts, then using your dremmel with a ball attachment insert it into the hole and start working behind the planking on the balsa from the centre out, bits of the triangles will start to come away, take your time and keep going, don't use the Dremmel on the outside edges of the ports, always work behind them so you don't round anything off and the triangles will just pop out, sand off the sides as you normally would, paint black, job done.  Gibbo attached the following image(s): Building: DelPrado HMS Victory. Building: DeAgostini Sovereign Of The Seas.
Nicely done Gibbo, looking good..... Regards Alan
Nice progress looking great mate Jase “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
 Nice work Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Planking done up to layer 12, dummy cannon supports painted, cut and glued in place, broke the top of a couple of ribs with the sanding block while sanding but easily fixable, and then cut out the gun-ports.    Gibbo attached the following image(s): Building: DelPrado HMS Victory. Building: DeAgostini Sovereign Of The Seas.
Looking really good Gibbo
Coming along Gibbo, very nice clean work.... Regards Alan
Nice planking Gibbo. I like the idea of cutting gun ports as you go, much better than being faced with a huge expanse of hull and trying to mark them out as on the sovereign. Man he took his time in the sun Had a dream to understand A single grain of sand He gave birth to poetry But one day will cease to be Greet the last light of the library...We were here!
nightwisher wrote:Nice planking Gibbo. I like the idea of cutting gun ports as you go, much better than being faced with a huge expanse of hull and trying to mark them out as on the sovereign. Yeah it does make you feel like you're actually getting somewhere. Cheers. Building: DelPrado HMS Victory. Building: DeAgostini Sovereign Of The Seas.
Guest (13)
