Issue 34 Step 7 Options
SimonC
#1 Posted : 03 August 2015 11:51:09
Rank: Amateur Level 1
Not sure if I have a problem here. Should step 7 'prepare a 150mm long strip and fix it starting from frame 2...' mean that this strip lies completely above frame 2 - or should it be resting on part (or all) of it? Ten rows of bamboo strips covers all but about 2mm of frame 2 on my model. On the starboard side 10 rows cover all of frame 2.
I have read several posts about slight width differences of bamboo strips which might account for discrepancies but are still a little uncertain what the final height of the bamboo strips should be. Is the reference point the top of frames 2 and 27 or should I go higher than this to follow Tomick's and the magazines instructions?
#2 Posted : 03 August 2015 14:05:21
Hi there SimonC...I think that you will find it alright as the bow planking will be trimmed in a later issue...Keep following Tomicks instructions and you won't go wrong...Hope this helps...
Wink ThumpUp
#3 Posted : 03 August 2015 14:25:45
BigGrin Hi Simon just put a plank on top as this will be cut down later in the build just make shoure the plank is well glued to the other oneThumpUp Hope this helps
Happy building rgd Martyn
SimonC
#4 Posted : 04 August 2015 10:12:25
Thanks Martyn and Jonny. I will do as advised and carry on as per instructions.
This page was generated in 1.318 seconds.
