 Rank: Master     Groups: Registered
Joined: 26/04/2014 Posts: 1,496 Points: 4,400 Location: Essex
Just a couple of questions for those who have done it. Firstly when gluing the radiator housings to the monocoque why is only glue used on a small section and secondly it says to fit the front under body then remove it a couple of times. Are we just holding it on or is it to be properly screwed on? Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Dodge charger build complete https://forum.deagostini....1686229545.1.1.utmcsr=(direct)|utmccn=(direct)|utmcmd=(none)&__utmv=-&__utmk=9709046
Hi Steve As far as I can remember the two strips on the side of the radiator housing's slot into the monocoque's recesses on each side this holds both the housings in place and although a small gluing area its all fine. It is also supported by the floor when its in place so just store it placed on top of it until final fixing. As for the underbody I think its removal has something to do with when the engine,gearbox and mono are finally joined together as one piece. Regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
That makes sense. Cheers andy Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
