Issue 65 assembly guide Options
Explosive
#1 Posted : 12 August 2015 14:15:26
Rank: Newbie
After run oil required during assembly in issue 65 I was only able to purchase Zap After run 2 Engine cleaner and corrosion inhibitor is this basicly the same product
AcE_w1zArD
#2 Posted : 13 August 2015 23:45:26
Sounds like essentially the same stuff :)
Explosive
#3 Posted : 15 August 2015 10:25:45
Rank: Newbie
Thanks for replying i appretiate the inputBigGrin
#4 Posted : 15 August 2015 10:35:00
Hi and a warm welcome to the forum. Will see if I can get someone to give you a definitive answer.... Cool Cool
Explosive
#5 Posted : 17 August 2015 13:16:32
Rank: Newbie
Thanks guys much appreciated . Tim BigGrin
#6 Posted : 17 August 2015 19:46:47
Hi Tim, have been asking around and haven't come across anyone who has used this material before but the consensus is that it sounds as if it is the same.... If I hear anything different then I'll contact you....
AcE_w1zArD
#7 Posted : 17 August 2015 23:46:36
The same stuff is available in the UK (after a little digging)
http://www.sussex-model-...uk/shopexd.asp?id=25502
It sounds like essentially just plain old after run oil, just with a fancy description;
Quote:
Treats engines and inhibits corrosion from forming. Adding After Run 2 to the engine protects all of the internal parts. One treatment lasts for months. Ideal for coating metal push rods before inserting them into sleeves.
Corrosion Inhibitor
penetrates existing corrosion
Protects engine bearings during storage
Theres nothing in there that any other after run oil wont do.
Explosive
#8 Posted : 22 August 2015 12:40:20
Rank: Newbie
Thanks guys for all the input this is a great forum and you all have been more than helpfull best wishes TimBigGrin BigGrin
This page was generated in 0.473 seconds.
